Today, I received a box!
In that box, were things!
One of those things was a 1/2" ratchet
The head is multi positional and lockable
See!
It even allows you to attack the 1/2" sockets that are included!
The 1/4" version is identical, except half the size
Also included is a multi bit screwdriver
Which works with the included long reach bits!
And they work with the 1/4" ratchet, using the included adapter!
And that all works with the included extension, it's almost like this is a set!
The long bits also work with my trusty 7.2v impact screwdriver, result!
