Can fuse board effect wifi router
18 Oct 2002
As title really.
At the moment my router is in same walk in cupboard as the fuse board as that where master BT socket is and there were engineer installed my opemreach modem.
The consumer unit/fuse board shouldn't do much harm.
The fact that the router is inside a cupboard would be more of a problem; it's one more wall for the wireless signal to get through.
Even if I put the wifi device next to the router it sometime high and some time low speed. Hard wire is always same speed.
Yes anything electrical can affect it. I used to have my router behind the tv with lots of wires behind there. Totally crippled the wifi
So an ADSL router worked there but a new router doesn't?
I would argue that it isn't electrical interference and more a dodgy/faulty router.
Well looks like the fuse board or somthing in that cupboard upset somthing. I took the faceplate off the master socket so the extension socket in lounge could receive fibre connection. Ta da high speed stable internet
if you have plenty other networks in your area you will have to put it on auto as i bet all of their rubbish routers will also be on auto.
must have been fuse board or somthing hidden behind walls played Hovac
You said removing faceplate and connecting to the diagnostic socket fixed it, surely that means it's the faceplate filter that has degraded not some mystical demon behind your walls.....
