CUDA Vegas Pro
19 Feb 2007
Sol
I've been using Vegas for quite some time now and was wondering if anyone knew how to enable CUDA acceleration as it doesn't seem to be working even if I use the option.
Is there an ini edit or something ?
Nah, it just doesn't have it. Better off using the CPU Dice :(
For me on what file output I have tested GPU acceleration only works on MP4 Mainconcept
This
XB7uuJLDkwVRKvcuHUJ5XvqMDVDe_MKTfAfkzByNo3Q
Then it will render using GPU
s0i4ceDxW5PkMxOVxFzftYCNi5u_IzDFd6_8FQnExeI
Took me an hour to encode my CQC ED 6 minute 1440P vid yesterday :(
It is Sony who haven't implemented Cuda support from reading about on Mxwell.
NVCUVENC is dead Vegas switched to NVENC tho it seems not for Maxwell.
Switch to OpenCL tho you would be much better off with an AMD card for that.
takes me around 20mins for a 15 min video. I dont add in any extra bitrate or anything though, I keep mine close to raw as I can. Raptr does a very good job keeping the bitrate at target level.
Nope but I will :)
An hour ? Usually only takes me around 10 minutes for a 10 minute video, Do you do a double pass by chance ?
I have double pass, higher bitrate and a couple of other settings raised. It keeps pretty decent quality for Youtube but does come at a time consuming cost. That same thing would only take around 15/20 mins with the OG Titan :(
