Prescription swimming goggles
Man of Honour
18 Oct 2002
Northallerton/Harrogate
Hi,
I'm about -2.5 in each eye with a bit of astigmatism, so I have those Toric contact lenses.
Does anyone know if anything like this is available in a swimming goggle (off the shelf) - I've found some -2.5 for about £20 but they're not wonky vision correcting... Not that it REALLY matters, I can see okish in standard lenses, from what I can remember...
I just don't want to be completely blind when swimming, and wearing contacts under goggles is annoying if they leak even slightly.
My requirements are a bit different but i got some Sutton OPT9000s because a lot of them don't have the option for different powers in each lens, or as much hyperopia correction as i need. They're solid goggles, but they only have options for lens power in intervals of one dioptre. I haven't seen any that offer astigmatism off the shelf, doubtless you could get some custom made but considering the refractive index of water messes with your sight as well i think the key thing is just to get in the ballpark, unless you're really serious about swimming.
Thanks, I'm not; I just don't want to crash into anyone/fall in the pool before I am ready to get in etc. I'm not actually THAT blind that either of those would happen, but I'd just like to be able to see underwater a bit better than "not really at all". Think I'll go with the ones I've found.
The weird thing about short sightedness is that you might actually find you're able to see normally underwater anyway, because of how the refractive indexes work.
