970 and 390 basically same performance.
vram is basically a troll.you will struggle with either card if it needs that much performance vram aint gunna help.
they are 1080 cards for running maxxed out. which they do it very well and will do for next two years.
out of the both. amd generally has better colours image quality.
970 is generally quicker at 1080 regardless of what people say.
Is that true? In the vast majority of threads I've read, people recommend the 390 > 970 because it's more powerful for the same money.
Precisely.
Having more vram is only an advantage if you can tap into it and 99% of the time you'll run out of grunt first. Neither the 970 nor the 390 can max The Witcher 3 at 1080p without dropping to 30-40fps and how much vram does the game use up at that res? <2GB?I can run it at 1440p with minor quality compromises and without BrokenWorks but I have to settle for around 45fps. The vram is still not a problem, it's the grunt of the card.
Between the 970 and 390, you can basically toss a coin (unless you prefer the features of a specific brand/honestly believe 8gb will make a difference) or grab a decent second-hand 970 which will be better value.
forgot to say; flat out not interested in ATI cards as they fkd me off greatly in the past, w/ performance and customer "service". That aside, the far lower power draw is what i'm looking for.
thanks again.
