Hi,
I have the H100i many years now (around 3). However recently when the CPU gets warm there is a loud ticking/cracking noise, the cpu temp skyrockets to 64C with barely a load on 2 cores, and both pipes are hot.
If I restart the system, the noise is gone after awhile and one of the pipes gets cold again, while the other is warm (not hot).
If I do not overclock the CPU and run it at stock speeds, regardless the load (even full) it will take hours at full load to eventually have the same issue.
Do you believe the cooler it on the way out? Because if so, I do plan to start building a custom loop sometime soon, and need to start looking right now for blocks (2011 for the 4820K and the 295X2).
Cheers.
Cheers.
