Lumia 950
Specs:
Height: 145 mm
Width: 73.2 mm
Thickness4: 8.2 mm
Weight: 150 g
Display size: 5.2 ''
Display resolution: WQHD (2560 x 1440)
Display colours: TrueColor (24-bit/16M)
Display technology: AMOLED, ClearBlack
Pixel density: 564 ppi
Display features: Orientation sensor, Sunlight readability enhancements, Corning® Gorilla® Glass 3, Easy to clean, High brightness mode, Lumia Color profile, Wide viewing angle, Automatic brightness control
Touch screen technology: Super sensitive touch
Main camera: 20.0 MP
Camera Focus Type: Auto focus with two-stage capture key
Camera optics: 6-lens optics
Stabilization: Optical image stabilization
Oversampling: Yes
Sensor size: 1/2.4 inch
Main camera f-number/aperture: f/1.9
Camera focal length: 26 mm
Camera Flash Type: Natural flash
Camera features: Backside-illuminated image sensor, PureView, True 16:9 sensor, Fast Focus, High resolution zoom
Camera minimum focus range: 10 cm
Front-facing camera
Front camera: Full HD 5MP wide angle
Front camera f-number/aperture: f/2.4
Front camera features: Still image capture, Video call, Video recording
Front camera video resolution: 1080p (Full HD, 1920 x 1080)
Video recording
Main camera video resolution: 4K (3840 x 2160)
Camera video frame rate: 30 fps
Video recording features: Video zoom, Optical image stabilization, Continuous autofocus, Video light, Lumia Rich Recording with four microphones
Video recording formats: MP4/H.264
CPU name: Qualcomm® Snapdragon™ 808
Number of cores: Hexa core
Clock rate: 1800 MHz
Mass memory1: 32 GB
RAM: 3 GB
Maximum memory card size5: 200 GB
Expandable memory card type: MicroSD
User data storage: In device, OneDrive cloud storage, App and data storage on memory card
SIM card type: Nano SIM
AV connectors: 3.5 mm stereo headset connector, DisplayPort over USB-C
Charging connectors: USB-C
System connectors: USB-C
USB: USB 3.1
Bluetooth: Bluetooth 4.1
Sensors: Ambient light sensor, Accelerometer, Proximity sensor, Barometer, Gyroscope, Magnetometer, SensorCore
Replaceable battery: Yes
Battery capacity: 3000 mAh
Battery voltage: 3.8 V
Charging3: Built-in wireless charging, Fast charging
Wireless charging standard: Qi
Maximum standby time: 12 days
Maximum talk time (2G): 23 h
Maximum talk time (3G): 18 h
Maximum music playback time: 67 h
Maximum Wi-Fi network browsing time: 9.5 h
Maximum video playback time: 10 h
Design details: Exchangeable back cover
Other user interface features7: Glance screen, Tactile feedback, Voice Commands, Voice dictation in edit fields
950XL
Specs:
Height: 151.9 mm
Width: 78.4 mm
Thickness4: 8.1 mm
Weight: 165 g
Display size: 5.7 ''
Pixel density: 518 ppi
Display features: Orientation sensor, Sunlight readability enhancements, Easy to clean, High brightness mode, Lumia Color profile, Wide viewing angle, Corning Gorilla Glass 4, Automatic brightness control
Oversampling: Yes
Front-facing camera
Video recording
CPU name: Qualcomm® Snapdragon™ 810
Number of cores: Octa core
Clock rate: 2000 MHz
Mass memory1: 32 GB
RAM: 3 GB
USB: USB 3.1
Battery capacity: 3340 mAh
Maximum talk time (2G): 25 h
Maximum talk time (3G): 19 h
Maximum music playback time: 75 h
Maximum Wi-Fi network browsing time: 11 h
Maximum video playback time: 11 h
Continuum ( SOLD SEPERATLY * as far as we know its not bundled with the phones)
Width: 64.1 mm.
. Height: 25.6 mm.
. Thickness: 64.1 mm.
. Weight: 230 g.
.Cable length: 100 cm.
Charging connectors: USB-C.
.AV connectors: DisplayPort, HDMI.
.System connectors: DisplayPort over USB-C.
.USB: 2 x USB 2.0, USB 2.0 high current charging port.
.Video resolution: up to 1080p (Full HD, 1920 x 1080).
.Content protection: High-Bandwidth Digital Content Protection (HDCP) 1.3 / 1.4.
.UI features: Gadgets app.
Also, this will work wirelessly with your phone, it does not need to be plugged in.
Changeable Covers:
Some are leaking out, real leather ones etc, its also looking like you might be able to change the bevel style/ colours as well.
Specs:
Height: 145 mm
Width: 73.2 mm
Thickness4: 8.2 mm
Weight: 150 g
Oversampling: Yes
Front-facing camera
Video recording
Mass memory1: 32 GB
RAM: 3 GB
USB: USB 3.1
950XL
Specs:
Height: 151.9 mm
Width: 78.4 mm
Thickness4: 8.1 mm
Weight: 165 g
Oversampling: Yes
Front-facing camera
Video recording
Mass memory1: 32 GB
RAM: 3 GB
USB: USB 3.1
Width: 64.1 mm.
. Height: 25.6 mm.
. Weight: 230 g.
Changeable Covers:
