£1500 Gaming Pc first build
7 Oct 2015
Hi I would like to build my own pc for gaming, really want it for fallout 4(plus other games). I don't have a lot of experience with building pc or choosing parts, It would be much appreciated if you could please help me with this build. I don't need a keyboard or mouse and would be willing to go over £1500 if it will significantly improve something. Thank you.
Hi and welcome.
Do you need a copy of windows and a monitor?
Any particular preference on a colour scheme?
Are there any constraints we should consider? Like portability, size (both of PC and monitor), noise, etc? Will you be overclocking?
My recommendation would be to drop to 980, get a AOC G2460PG 24" 1920x1080 TN G-Sync 144Hz 1ms.
This would let you get a better cooler like Corsair h100 series (water cooled), this would be better for overclocking.
980ti, a decent monitor, no need to spend for silly money on a AIO cooler.
Similar to Stulid, it'll probably be around that ballpark. 500GB gaming + OS SSD, 2TB gaming + data drive.
YOUR BASKET
1 x Zotac GeForce GTX 980Ti AMP Edition 6144MB GDDR5 PCI-Express Graphics Card (ZT-90503-10P) £499.99
1 x Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - OEM £199.99
1 x Crucial BX100 500GB SSD SATA 6Gbps 7mm Solid State Drive (CT500BX100SSD1) £129.95
1 x Asus Z170 Pro Gaming Intel Z170 (Socket 1151) DDR4 ATX Motherboard £119.99
1 x Microsoft Windows 10 32/64-Bit - USB Pen Drive - Retail (KW9-00017) £85.99
1 x SuperFlower Leadex Platinum 550W Fully Modular "80 Plus Platinum" Power Supply - Black £74.99
1 x NZXT Source 340 Midi-Tower Case- Black Window £59.99
1 x Kingston Fury Black 8GB (2x4GB) DDR4 PC4-21300C15 2666MHz Dual Channel Kit - Black (HX426C15FBK2/8) £44.99
Total : £1,284.86 (includes shipping : £12.50 Ex.VAT).
CPU Cooler is bundled with motherboard.
Can drop for a GTX980, more money for a i7, a widescreen monitor.
But like Stulid, that's the general ballpark I'd aim for. Keep the case and PSU decent (Leadex / Seasonic manufacture).
Here's my slightly OTT build, arriving soon, which doesn't have a monitor or OS, and has premium components you don't really need.
YOUR BASKET
1 x OcUK GeForce GTX 980Ti "Reference Design" 6144MB GDDR5 PCI-Express Graphics Card £529.99 *** actually a EVGA with no backplate, but not in stock ***
1 x Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor - Retail £329.99
1 x Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU) £149.99
1 x EVGA SuperNova P2 850W '80 Plus Platinum' Modular Power Supply £124.99
1 x Fractal Design Define R5 Midi Tower Case - Blackout Edition Window £94.99
1 x Kingston Fury Black 16GB (2x8GB) DDR4 PC4-21300C15 2666MHz Dual Channel Kit - Black (HX426C15FBK2/16) £89.99
1 x Toshiba 3TB 7200RPM SATA 6GB/s 64MB Cache HDD - OEM (DT01ACA300) £71.99
1 x Pioneer BDR-209DBK 16x SATA Internal BD/DVD/CD Burner - No Software £53.99
Total : £1,580.90 (includes shipping : £12.50 Ex.VAT).
Thank you for the builds they look good, although I was speaking with a friend and he told me I should try to get a better psu. What do you think or recommend any? He told me everything else was on point.
Unless you want the option to add a 2nd gfx card in the future (thus needing a bigger 850W PSU) then that one is fine.
Seasonic is still king, but you pay a premium. Gold or plat PSU for that kind of budget. 550W minimum, 650W and it will run pretty much in fanless mode 90% of the time. 750W / 850W for SLI.
Leadex manufacture (SuperFlower, EVGA) is a good second. Enermax makes good PSUs, but not very common (Delta Design, very, very good). Corsairs are still OK, used to be 100% seasonic internals but not anymore.
post your components so we can double check in case.
