Home Oil (Kerosene) Boiler Advice
Man of Honour
21 Feb 2006
I have oil fired heating at home as we have no mains gas and it was built to be oil fired. Last week the tank ran dry, not for the first time, when our Watchman failed to tell me it was low, not for the first time. :mad:
The boiler is around 12 years old and though I am told it was a great boiler when built I am considering replacing it, assuming (rightly or wrongly) that tech and efficiency will have improved in that time. I am unable to restart my current boiler so have a local engineer coming out next week to fix it but I am planning to discuss replacement options and wondered if we have any engineers here that can give me some pointers of what's good or what I need to consider.
Tank has 1800L in it having topped it up and sits about 50 yards from the boiler.
Have you tried bleeding it? There'll be a little screw to loosen, it'll hiss then some oil will come out, tighten and you're done.
Also, how old are you? You always sound quite old and the plumber told my dad he'd be dead before he got his money back on a new boiler.
I'm 48 and I am not going near the boiler outside trying to restart it. You make is sound easy, I will end up on fire I am 100% sure of it and I know from experience it's not that simple as the oil needs to be pumped through as I have had this done before. It's probably less about the money and more about the reliability. The boiler has been temperamental.
There is a button, outside on the burner, usually a red push button, turn your heating on, then go out and push the button, just hold it down, it'll fire the beasty, hopefully drain any airlock in the process and you're good to go.
In 12 years I doubt oil burning tech has changed much at all in regards efficiency, it seems to be a stagnant market compared to gas.
There is a button, outside on the burner, usually a red push button, turn your heating on, then go out and push the button, just hold it down, it'll fire the beasty, hopefully drain any airlock in the process and you're good to go..
As I said, it won't. Ive done it about 10 times today and the boiler can not pull the oil through and now the pump has died. I've been here before, I've arranged for my oil provider to fit a monitor which goes back to their base so then can manage it and keep it topped up so this doesn't happen again.
I believe it's a Trianco WM70 HE EXTERNAL
Actually think that's wrong but it's a Trianco but might be a Eurostar 50/70
Trianco Eurostar 50/70 has an efficieny of 84.5%
Looking at a new boiler would be 90% effiecient so an overall saving of 5.5% a year
Take into account a new boiler and fitting expense i doubt it would be worth the cost.
Thanks, appreciate the heads up!
To be honest the boiler is a bit triggers broom, it's had a few parts replaced over the years and I fear a new pump might be needed, which will be its 3rd. :(
All depends on cost of replacement pump but a new oil fired boiler aint cheap.
Have yo looked at a boiler care plan ?
I have never looked at the plan even though people keep mentioning it. I go yea, I will have a nose....then something else crops up and I forget all about it :D
Have a poke around the boiler even just for curiosity sake.
When we first ran out of oil last year, I couldn't get it going, especially as I had no experience.
Had a browse around and found a manual online for the riello burner within the boiler. All I did was loosen the bleed plug with a rag around it and let the kero bleed through and into a small plastic container. Tried a few more test fires (red reset button) with a little more bleeding then the thing came alive again with the air out of the system.
Not hard and I didn't implode :p
But our tank is down the bottom of the garden ~25m away on stilts so mavity fed. New one is 3m from boiler and lower than the boiler, so am going to have to fit new pipework and a tiger loop. Should be fun :D
If it comes to buying a new one, i would seriously look at an air source heat pump. We have just replaced a couples oil boiler for an air source heat pump after their boiler leaked and oil going everywhere. Not only is it more efficient but the payback from the government will see them very well over the next 7 years. Of course at the moment oil is at a great price tho
I have a listed building and live in a preservation area, so don't really want big boxes on the side of the house, which that type of heating seems to demand?
