[TW]Fox;28669967 said:Why does he keep buying them if they all do that!?
because they are cheap
[TW]Fox;28670123 said:No you can't![]()
For sure Only by like 5% in 45mins via the mpg digital readout. But does drain quicker with using it.
I've popped to halfords and picked up a dehumidifier pillow![]()
But surely the mpg reading would go down anyway if you're sat idle because you aren't moving?
Just run the aircon constant for a week or so to get rid of any damp in the carpets etc and you won't need it on permanently after that.
I find it odd that someone would spend 10-15k on a car & then worry about 1, maybe 2 MPG which is probably going to amount to a couple of quid a month.
If money is that tight why buy a new car?![]()
it uses absolutely no fuel at all.
[TW]Fox;28671701 said:This is clearly false.
