Fury x vs 980Ti
hey btw jedi since i see you have the same monitor asus rog swift does it have any software that needs to be downloaded like drivers? i see it comes with a disk but i dont have a dvd drive :s lol
The only thing you need to check is that 144Hz is selected as the refresh rate in the Nvidia driver+games.
And Gsync is working/ON.
may get the corsair i think in someways i like them more do you think onboard sound be ok or do i need a sound card
On-board is a lot better than it used to be. Its quite good by most standards and on par with most cheapish sound cards. You have to invest in a decent sound card to get notable improvements vs on-board sound and it's usually features that separate on-board vs a sound card. Basically on board is fine lol.
hey will the fx 8350 bottle neck or whatever the 980 ti really badly? since games like armored warfare and gta 5 my fps is like 40 50 even though when i use msi after burner the cpu is like 60% usage and gpu is also like 60% usage :?
thanks GothicCorpse
ok cool can you show me what to get im after a good red and black motherboard the 5820k or 5830k and good ddr4 red or black type memory :) right now im using 980 ti
