Man of Honour
- 17 Nov 2003
- Southampton, UK
So in this case the Local Authority/Council...
Possibly, but again they would need to serve notice to enter the property.
Expanding foam in the letterbox would most certainly be criminal damage.
Assuming there was some way of proving who did it![]()
Like I said, if you're going non-legal, you may as well do it properly.
Hence why I proposed them going in at the same time as the body recovery folks. Two birds. One stone.
I stand by my original statement that as far as I'm concerned a large part of the body is still there!
That's bad news Rob. If Jess brother wasn't stopping here you would all be welcome to stop over till it was sorted. He moved in on a temp basis for while.
I actually do this as part of my job, it isn't pleasant and it Is the type of odour that once you have smelled it you never ever forget what it is. Sticks to the insides of your nostrils.
Not a cheap clean up job either and usually takes a few sessions with specialty equipment to eradicate the odour given the amount of time it has had to seep into the building.
Bit of an update, an ENV officer left a voicemail. They have been to try and gain entry to the flat. I'm guessing that means knocking on the door since its secured, having a sniff and look through the letterbox and seeing what the situation is.
They have now said they will try and get a warrant to gain entry, presumably to assess further and potentially clear. Hope so anyway and maybe what they meant earlier by getting around the legislation with police assistance? It sounds positive at the moment though.
