Hi there
Three stonking SSD deals for you:
Kingston HyperX Savage 240GB SSD 2.5" SATA 6Gbps Solid State Drive (SHSS37A/240GB) @ £64.99 inc VAT
Powerful performance, unparalleled design.
HyperX® Savage solid-state drive off ers extreme performance for the extreme performer. The fastest HyperX SATA-based SSD, it’s powered by a quad-core, 8-channel Phison S10 controller that delivers incredible speeds of up to 560MB/s read and 530MB/s write, with read/write IOPS up to 100k/89k. The result is ultra-responsive multitasking and an overall faster system that maintains performance even as the drive fi lls up.
With its low profi le and slim, 7mm form factor, HyperX Savage SSD fi ts in most notebooks, desktops and HTPC builds. Its unique look, with highquality red steel and aluminium casing and diamond-cut design, helps you stand out in the crowd and complements the latest PC hardware.
It’s available in a bundle kit that includes everything you need to install Savage in your existing system, including a USB 3.0 enclosure to transfer data from 2.5" hard drives; a 2.5"–3.5" adapter to mount in a desktop environment; SATA data cable; multi-bit screwdriver and Acronis® data migration software. HyperX Savage SSD is 100 per cent factory tested and backed by a three-year warranty, free technical support and legendary reliability.
- Powered by a Phison controller with SATA Rev 3.0 (6Gb/s) performance
- Speeds of up to 560MB/s read and 530MB/s write
- Form Factor: 2.5"
- Interface: SATA Rev. 3.0 (6Gbps)
- Capacity: 240GB
- Controller: Phison PS3110-S10
- Compressible Data Transfer (ATTO): 560MB/s Read - 530MB/s Write
- Incompressible data transfer (AS-SSD and CrystalDiskMark): 520MB/s Read - 510Mb/s Write
- IOMETER maximum randon 4K read/write:100,000 / 89,000 IOPS
- Random 4K read/write: 93,000 / 89,000 IOPS
- Life expectancy: 1 million hours MTBF
- Warranty: 3-Years warranty with free technical support
Was [£85.99] Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Samsung SM951 256GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive (MZVPV256HDGL-00000) @ £119.99 inc VAT
The new, best thing in storage technology, NVMe, which has been hot property in the server market due to it's extreme transfer speeds, has now reached the desktop market. The Samsung SM951 M.2 PCIe NVMe SSD is the new performance leader in M.2 form factor SSD's. Providing up to 2150MB/s read and 1260MB/s write sequential data transfer rates, along with astounding random I/O ratings of 300k reads and 100k writes.
The Samsung SM951 (NVMe) is compatible as a boot device in a wide variety of systems with a free PCIe 2.0/3.0 M.2 socket. This includes Z170/Z97/X99 based motherboards, modern notebooks, and tiny form factor PC's like the Intel NUC. It can also act as additional super high speed storage in almost any desktop with a spare PCIe slot when combined with a PCIe adapter.
Key Features:
- Extreme performance - up to 2150/1260 sequential read/write data transfer rates and 300k/100k read/write random IOPS
- Bootable in Windows 7/8, Mac OSX (2006-2010 Mac Pro only) and Linux
- PCIe 3.0 device, backwards compatible with PCIe 2.0
- Small M.2 form factor plugs straight into your PCIe-based M.2 socket with no additional cables required
Please Note.</b> Some M.2 motherboards only support SATA 6Gbps speeds or PCI-e x 2 lanes. You need to make sure your board supports NVMe and PCI-E x4 Lanes to get the full speed from this SSD.
Specification:
- M.2 PCI-E 3.0 (x4) interface on an NVMe Compatible Motherboard
- MLC NAND
- Read Speed: 2150MB/s-2650MB/s
- Write Speed: 1260MB/s-1550MB/s
- IOPS: 300k/100k
- Warranty: 2yr
Was [£129.95] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Samsung SM951 512GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive (MZVPV512HDGL-00000) @ £239.99 inc VAT
Key Features:
- Extreme performance - up to 2150/1550 sequential read/write data transfer rates and 300k/100k read/write random IOPS
Specification:
- MLC NAND
- Write Speed: 1550MB/s-1650MB/s
- IOPS: 300k/100k
- Warranty: 2yr
Was [£269.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
- Form Factor: 2.5"
- Capacity: 240GB
ORDER NOW
Key Features:
Specification:
- MLC NAND
- IOPS: 300k/100k
- Warranty: 2yr
ORDER NOW
Key Features:
Specification:
- MLC NAND
- IOPS: 300k/100k
- Warranty: 2yr
ORDER NOW
