** 24HR INSANITY DEAL: 8 PACK 980 ONLY £349.99 !! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
For the remainder of This Week ONLY we have dropped the incredibly 8 Pack GTX 980 to just £349.99 Inc. VAT
Whilst our competitors are selling regular GTX 980's for around £380, we are offering one of the best best 980's which rivals EVGA KingPin and Asus Matrix which still retail around £450-£500 area.
Such making this a rather incredible deal, £150 less than standard 980Ti's and £200 less than OC edition 980Ti's makes this 980 an absolute bargain.
Infact it is typically less than £100 more than a 970, making this 980 a very worthy consideration for anyone looking at a OC Edition 970.......
KFA2 GeForce GTX 980 "8Pack Edition" 4096MB GDDR5 PCI-Express Graphics Card @ £349.99 inc VAT
8 Pack branches out further now with his very own graphics card. Aesthetically this is a great looking card with black PCB, Black/Gunmetal cooler, black fans and a black 8 Pack backplate. Enough about the looks this card has a further revised PWM/VRM compared to the original HOF cards. That means even great overclocking potential resulting on average far higher overclocks being made reachable like 1500MHz+ and region of 8000MHz memory clocks (not guaranteed).
With so much performance on tap out the box, infact this card out the box out performs any other 980 on the market and gets very close to Titan X performance, this card is an absolute beast.
Remember the perfect companion for the 8 Pack graphics card is of course the worlds most powerful and stable 8 Pack 2000W power supply built by Superflower.
Key Features:
- Completely redesigned PCB layout from the ground up, optimized for GM204
- 10 layer manufacturing process in 8 Pack signature black/gunmetal cooler
- Extended PCB width for optimized layout and cleaner signal
- Advanced GALAX exclusive "Triple Force" cooler
- 2x 80mm fan + 1x 90mm fan
- 4x 8mm heat pipes + 3x 6mm heat pipes (total 7 nickel-plated heat pipes)
- Copper base cooler
- Integrated MOSFET heatsink
- Customizable top HOF LED (control blanking frequency, brightness with GFE)
- Plastic cover with premium die-cast aluminum accents
- Anodized aluminum backplate protects components and reinforces PCB
- Next generation IR3595 Digital PWM controller provides 2X switching frequency vs. previous generation
- 8 phase GPU + 2 phase memory power
- IR3555 with next gen DrMOS and 60A output
- Aerospace-grade GALAX Extreme Power Inductors provide ultra-long life, high endurance and low noise vs. normal power inductors
- Hyper Boost technology acts like a hardware turbocharger, increasing fan speed and maximum power delivered to the GPU with the push of a button
- Hardware dual BIOS simplifies the tweaking process by enabling risk-free firmware updates and customization
- Prelim internal overclocking results: >1.5-1.6GHz on air, 1.55-1.65GHz H20, 2.1-2.2GHz on LN2
Specification:-
- Multi-layer ceramic capacitors
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Process: 28nm
- Core Base Clock: 1304MHz
- Core Boost Clock: 1418MHz (1440-1480MHz effective hyper-boost clock)
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 750W Premium PSU Required
- 180-500W TDP
- Dimensions(with Bracket): 308*129.1*49mm
- Dimensions(without Bracket): 294*116*46.1mm
- Review: http://www.kitguru.net/components/graphic-cards/zardon/kfa2-geforce-gtx-980-8pack-edition-4096mb/
- Warranty: 3yr
Was [£379.99] Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
I'd imagine the Ti is the reason Gibbo is trying to get rid of these. NVIDIA releasing the Ti for not much more than this cost at launch did steal it's thunder a bit, never mind what it did to the Fury X.
It's a great card though and more than enough for anything below 4k or 21:9 1440p resolution if you're air-cooled.
