- 12 May 2011
- Southampton
I have a 2003 BMW 330ci manual. It had its inspection 2 today and I had the following comments:
Missfire- plugs 3 and 5 replaced as part of inspection II
Possible Breather Valve required re misfire
'found' o/s/f antiroll bar link- remove and replaced
Annual check due
Rear shock absorber top mounts worn
Trailing arm bushes worn
Corrosion under n/s/r airbag ring
PDC faults stored
Diff bush split
Front brake hose starting to perish
Oil sensor gone
slight play in osf inner track arm joint
Coolant leak from thermostat housing- poss water pump required
Bowed radiator- requires replacement.
That's quite a list. Is all of this little niggley things (except the radiator!) or are they all pretty major and need doing?
What's a ball park £££ figure to fix for each item?
I'm normally not one to sell a car when something goes wrong with it, from the "it'll cost me more money to repair!!" perspective, but with this big list of items... What would you do? The car cost £3200 when I bought it a year ago, and i've put maybe £1250 into it in terms of servicing and replacement parts.
Annual check due
PDC faults stored
Diff bush split
Oil sensor gone
