Which tyre profile?
3 Jun 2012
Hey
So i have sourced some RX8 Alloys for cheap.
Being 18" i cannot reuse my tyres, which tbh is good as they suck.
I fancy some Rainsport 3's. I used these before on my old car and loved them, perfect for our weather and I felt safe.
But I am unsure which profile to match with the alloys.
They do 225/45/18, also 225/40/18.
I know the 45 profile would give a better ride quality, but by how much? and is it worth the extra outlay.
See the below for a price on them. Its £90 cheaper to get the 225/40/18! Smashing price of £54 each.
In my view, these tyres fit the bill, and are what i am after. I want a tyre that performs the best in the wet and still give very good grip in the dry. from my own experience and many others i can say that they do indeed fulfil that.
So No "them crap tyres there, here buy these at £100 a tyre!"
It depends on what the stock tyres are, as you'll need to maintain as close a rolling radius as possible or it will affect gearing & speedo accuracy. What's the stock tyre/wheel size?
Just a pointer as to why there is such a big difference in price - you have two different load/speed ratings there, which will probably affect the tyre make-up slightly.
As for what size, I'd just stick with whatever is recommended for the RX8 alloys from actual RX8 owners, which I think is 225,45,18.
So, just a quick look on Google suggest that your standard wheels & tyres and 205/50/17. If this is the case, then you should choose the 225/40/18, as your rolling radius and tyre circumference will be unchanged.
Oh I see.
Intresting, looking like 225/40 then.
Lucky for me they are cheaper :)
Thanks all!
Roughly for each size up up in dia or width drop a size in profile
For a more accurate there are calculators on the web just google tyre size calculator
Pretty sure the standard alloy was 18" and a 225/45/18 was fitted. Its what both of mine had.
Mine is on 17" alloys. 205/50/17. Just checked.
Just placed the tyres in the basket for the 225/40/18's :)
Now i just need to collect the RX8 alloys and get them Powdercoated over in Brum :D
