- 14 Feb 2011
If you're planning on upgrading the Cpu at some point you'll get the benefit of the faster card anyhow. Regardless of any bottlenecks i'd still buy the fastest card in your budget.
None. This is my first build and im currently PC-less!!What cpu you got at moment?
Nope! not at all. I'm kind of new to pc hardware, and am only familiar with intel products/naming system. So AMD is kind of confusing to me in general. Like i3/i5 equivalents and the models within those families.Does it have to be an Intel CPU?
I also read some reviews that said even the 6 core AMD one was worse than the 4 core i5.
Thats very subjective, they are different and get there performance in different ways, Intel use less higher performing cores while AMD use more lower performing cores.
Older games tend to favour Intel CPU's much more than newer games, that much is true.
If it was me with relevant budget constraints i would go for higher GPU performance and an AMD CPU rather than Intel CPU and lower GPU performance.
I use an AMD CPU with a GTX 970, which is more like a 780TI and its overclocked to the high heavens.
I don't get any bottlenecks at all.
Which AMD CPU do you use/would recommend?
Yep I will head on over to general hardware. I've had them built in the past, but I would like to try myself as its something I would like to learn to do.will put it together for you it all depends how good you are at building pc's buying a base unit might be worth it if you never build one before.
I always thought games prefer fewer cores that are higher performing, as current games cant utilise more than 4. But I think your point about the GPU makes logical sense. I'm also conscious of DX12 working well with current AMD cards, but i don't know how far away we are from DX12 games.
