Hi there
Some crackers on This WEEK ONLY, ending next Wednesday!
aoc q2577pwq 25" 2560x1440 ips professional widescreen led monitor - silver/black @ £199.99 inc vat
this monitor with qhd resolution ensures that users can enjoy a full view of a document, spreadsheet, or website at a single glance without the need of scrolling. ips technology is one of the highest performing panel technologies currently available for displays. this way, aoc makes sure users will greatly benefit from high accuracy in colour, contrast and wide viewing angles. in order to give users a variety of options for connecting different input sources, the aoc q2577pwq comes with displayport, hdmi, dvi and vga. also comes with aoc's flicker free technology that ensures a zero-flickering viewing experience.
raise or lower the screen to suit each individual’s height and seating preferences. the easy-to-adjust stand ensures hours of viewing or working comfort.
aoc stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. within the warranty period, any aoc displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge.
with 2560 x 1440 resolution, quad hd (qhd) offers superior picture quality and sharp imagery that reveals the finest details. the widescreen 16:9 aspect ratio provides plenty of space to spread out and work, plus allows you to enjoy games or movies in their original size.
features:
- enjoy 63.44 cm (25") of superb screen clarity on a sharp qhd 2560 x 1440 resolution monitor. plus, you get great colour consistency across an ultra-wide 178°/178° viewing angle.
- get exceptional colour accuracy and consistency right out of the box, with each monitor factory tuned at 99% srgb with a delta
- easy arrange lets you choose how you view your custom window layout. see all your applications tiled side by side with nothing buried
- smoothly pivot 90° clockwise or counter-clockwise, placing the thinnest edges side-by-side for an enhanced viewing experience, especially ideal for dual or multi-monitor set up
- the q2577pwq is vesa-compatible, so you can wall mount your monitor or attach it to the optional dell single monitor arm
specification:
- led backlit
- height adjustable
- swivel & tilt stand
- screen size: 25" ips widescreen
- resolution: 2560x1440
- contrast ratio: 80,000,000:1
- brightness: 350cd/m²
- response time: 5ms
- viewing angles (h/v): 178°/178°
- colours: 16.7 million
- inputs: 1x hdmi, 1x displayport, 1x dvi-d, 1x analogue
- vesa compliant
- warranty: 3 years on-site
was [£229.99] inc. vat
only £199.99 inc vat.
order now
asus vs229ha 22" 1920x1080 va widescreen led monitor - black @ £86.99 inc vat
delicate touches make a monitor truly great, vs229ha full hd led monitor, with 80,000,000:1 high contrast ratio and full hdmi, is optimized for the finest image and color quality. this approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. enter a spectacular world of colors with full hd 1080p (1920x1080) support and hdmi port.
vs229ha adopts 178°(h) / 178°(v) ultra wide viewing angle panel that eliminates color shift on your screen no matter where and how you look at it. aspect control function allows users to select a preferred display mode among full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
specifications:-
- screen size: 21.5"
- screen type: va
- backlight: led
- aspect ratio: 16:9
- recommend resolution: 1920 x 1080
- screen features: full hd
- pixel pitch: 0.248mm
- horizontal frequency range: 30khz - 80khz
- vertical frequency range: 56hz - 76hz
- response time: 5ms (gtg)
- contrast ratio: 1000:1
- dynamic contrast ratio: 80,000,000:1
- brightness: 250 cd/m²
- horizontal viewing angle: 178°
- vertical viewing angle: 178°
- tilt angle: -5°/20°
- vga port(s): 1
- dvi port(s): 1
- hdmi port(s): 1
- warranty: 3yr (on-site with asus - 01442 265 548)
was [£89.99] inc. vat
only £86.99 inc vat.
order now
iiyama prolite gb2488hsu-b1 24" 1920x1080 tn 144hz 1ms widescreen led super slim bezel monitor - black @ £199.99 inc vat
prolite gb2488hsu is a real game changer, giving true hardcore gamers the competitive edge they need to make split second decisions. it features a response time of 1ms, which ensures fluid and accurate transition between the images, and it effects ghosting or smearing issues directly. smooth and judder free graphics during fast paced games are guaranteed by the use of a high quality 144hz panel. ergonomic, height adjustable stand allows to adjust the screen position to your preferences easily. the prolite gb2488hsu is an ideal screen for the rts, fps console games and the demanding gamers who settle only for the best specifications.
specification:-
- diagonal: 24"
- panel: tn led
- display area: h x w 298.89 x 531.36 mm; 11.8" x 20.9"
- response time: 1 ms
- contrast: 1000 : 1 typical
- contrast: 5000000:1 acr
- brightness: 350 cd/m² typical
- viewing zone: horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- display colour: 16.7 million
- pixel pitch: h x v 0.277 x 0.277 mm
- native resolution: full hd 1080p, 1920 x 1080 ( 2.1 megapixel)
- horizontal sync: dvi/dp: 30 - 160 khz
- vertical sync: dvi/dp: 55 - 144 hz
- synchronization: separate sync
- digital input connector: dvi-d, 2 x hdmi, displayport
- hdcp: yes
- headphone connector: yes
- output connector: headphone socket
- usb hub: 2 outputs (v. 2.0)
- speakers: 2 x 3 w (stereo)
- anti-theft-device kensington-lock™ prepared
- certificates: ce, tÜv-bauart, gost-r, vcci-b, pse
- height adjustable stand: yes
- height adjustment: 130mm
- rotation (pivot function): 90°
- swivel stand: 90°; 45° left; 45° right
- tilt angle: 22° up; 5° down
- vesa mounting: 100 x 100 mm
- dimensions: w x h x d 568 x 388 (518) x 230 mm
- weight: 5.5 kg
- warranty: 3yr (on-site with iiyama - 01926 819 189)
was [£209.99] inc. vat
order now
aoc q2770pqu 27" 2560x1440 ips widescreen led monitor - black @ £289.99 inc vat
experience a new level of sharpness with this large 68.6 cm (27”) monitor. the q2770pqu utilises a state-of-the-art super pls panel with the stunning wqhd resolution of 2560 x 1440 pixels. with its d-sub, dvi-d, hdmi and displayport connectors, plus speakers as well as a usb hub integrated into the bezel, this energy-efficient display offers you a multitude of applications, delivering exceptionally crisp and vivid images for even the highest demands. benefit further from full ergonomic flexibility with 130 mm height adjustment, tilt, swivel and pivot (= portrait mode rotation) function. the q2770pqu comes in a classy black texturised design and features eco-friendly led-backlights .it fulfils sustainability certificates such as energy star 6.0, tco 6.0 and epeat gold. let the q2770pqu impress you today!
specification:-
- monitor size: 27"
- visible screen size: 68,6 cm
- screen format: 16:9
- brightness: 300 cd/m² (typ)
- contrast ratio dynamic: 80.000.000:1 (dcr)
- contrast ratio typical: 1.000:1
- pixel / dot / pitch: 0.311 (h) x 0.311 (v) mm
- display area: 597.89 (h) x 336.31 (v) mm
- viewing angle: 178°/178° (cr=10)
- response time: 5 ms gtg
- maximum resolution: 2560x1440@60hz
- recommend resolution: 2560x1440@60hz
- colors: 16.7 m
- connectivity: 1x vga, 1x dvi-d, 1x display port input, 1x hdmi
- dimensions (wxhxd): 642 x 558 (+130) x 245
- weight: 7.5 kg
- warranty: 3 years (on-site with aoc - 0808 234 3510)
was [£299.99] inc. vat
only £289.99 inc vat.
order now
asus pb287q 28" 3840x2160 tn 4k 60hz 1ms gaming widescreen led monitor - black @ £359.99 inc vat
asus enter the price war with their gaming 28" 4k monitor, just like other models sporting an impressive specification with a fast response 1ms tn panel, 60hz over displayport. the asus also has some innovations of its own such as a flicker free backlight to help reduce any flicker along with a fully adjustable stand.
experience games in such detail and realism like never before at 4k resolution, just ensure you have the lastest graphics cards and ideally in multi-gpu configurations to get the best from your 4k panel.
specification:-
- display screen size: 28" (70.8cm)
- panel type: tn
- brightness: 300cd/m2
- contrast ratio: 1000:1 (typ)
- dynamic contrast ratio: 10,000,000
- resolution: 3840x2160 (only over displayport at 60hz)
- response time: 1ms (gtg)
- flicker free backlight
- pip/pbp support
- viewing angle (h / v ): 170 ° / 160 °
- connectivity: 2x hdmi, 1x displayport
- stand: height adjust, pivot & swivel
- speakers: yes
was [£389.99] inc. vat
only £359.99 inc vat.
order now
iiyama prolite b2783qsu-b1 27" 2560x1440 tn freesync gaming widescreen led monitor - black @ £245.99 inc vat
the prolite b2783qsu is an excellent 27” qhd led-backlit monitor bringing the world of business and gaming together. the monitor offers accurate and consistent colour reproduction with wide viewing angles and a sharp high resolution 2560x1440 panel. its ergonomic stand offers 13cm height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. this monitor supports freesync™ technology, offering gamers the chance to experience fluid and fracture free gaming. triple input (dvi/hdmi/displayport) and a usb hub ensure compatibility with your desktop pc or notebook.
specification:-
- screen size: 27" (69cm)
- resolution: 2560x1440 wqhd
- panel: tn
- refresh rate: 60hz
- horizontal sync 30 - 90 khz
- vertical sync 50 - 75 hz
- contrast ratio: 1000:1 (120,000,000:1 dcr)
- connectivity: 1x dual link dvi, 1x hdmi 1.4, 1x displayport
- usb 3.0 hub
- freesync enabled
- dimensions: w x h x d 622.5 x 400.5 (530.5) x 230 mm
- weight: 6.1 kg
- height adjust stand with pivot, swivel and tilt
- warranty: 3yr
was [£259.99] inc. vat
only £245.99 inc vat.
order now
avexir core red series 8gb (2x4gb) ddr4 pc4-19200c16 2400mhz dual channel kit (avd4uz124001604g-2cir) - red light @ £39.95 inc vat
avexir core series is a simple yet elegant low profile premium design which incorporates an led tube which gives the led a gentle pulsing effect, giving your system not only an awesome look but also a very unique look as avexir has patents making it the only memory to use this gentle pulsing yet very impressive visual technology. avexir is only available from overclockers uk and caseking in europe.
avexir core series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. the core series is developed by avexir r&d team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
core series is designed to be a perfect visual match for asus rog, evga, asrock fatality, gigabyte and msi gaming mainboards, giving you a look which shall make you the envy of all your friends.
avexir strictly adheres to quality standards set by jedec (the joint electron devices engineering council) and iso9001.
with 100% hand-tested extensively in multiple pc major-brand motherboard environments at its rated speed, avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
features:
- black pcb
- black high performance heatspreaders
- led strobe lighting effect
- cas timings: 16-16-16-36
- dual channel kit: (2x4gb)
- 100% tested at 2400mhz in intel z170 skylake based motherboards
- lifetime warranty with ocuk
was [£49.99] inc. vat
only £39.95 inc vat.
order now
avexir core red series 16gb (2x8gb) ddr4 pc4-19200c16 2400mhz dual channel kit (avd4uz124001608g-2cir) - red light @ £79.99 inc vat
features:
- black pcb
- dual channel kit: (2x8gb)
only £79.99 inc vat.
order now
avexir core blue series 8gb (2x4gb) ddr4 pc4-19200c16 2400mhz dual channel kit (avd4uz124001604g-2ci) - blue light @ £39.95 inc vat
features:
- black pcb
order now
avexir core blue series 16gb (2x8gb) ddr4 pc4-19200c16 2400mhz dual channel kit (avd4uz124001608g-2ci) - blue light @ £79.99 inc vat
features:
- black pcb
order now
avexir core white series 8gb (2x4gb) ddr4 pc4-19200c16 2400mhz dual channel kit (avd4uz124001604g-2ciw) - white light @ £39.95 inc vat
features:
- black pcb
order now
avexir core white series 16gb (2x8gb) ddr4 pc4-19200c16 2400mhz dual channel kit (avd4uz124001608g-2ciw) - white light @ £79.99 inc vat
features:
- black pcb
order now
avexir core blue series 8gb (2x4gb) ddr3 pc3-12800c11 1600mhz dual channel memory kit (avd3u16001104g-2cw) - blue light @ £35.99 inc vat
with 100% hand-tested extensively in multiple pc major-brand motherboard environments at its rated speed, avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.</p>
features:
- black pcb
- blue led strobe lighting effect (see product images)
- spd programmed at: jedec standard 9-9-9-24 values at 1333mhz.
- cas timings: 11-11-11-24
- 100% tested at 1600mhz in intel & amd based motherboards
- lifetime warranty
- sandybridge compatible
- bulldozer compatible
only £35.99 inc vat.
order now
avexir core red series 8gb (2x4gb) ddr3 pc3-12800c11 1600mhz dual channel memory kit (avd3u16001104g-2cir) - red light @ £35.99 inc vat
mpower red series is designed to be a perfect visual match for asus rog, evga, asrock fatality and msi gaming mainboards, giving you a look which shall make you the envy of all your friends.</p><br />
features:
- black pcb
- black/red high performance heatspreaders
- red led strobe lighting effect
- lifetime warranty
order now
avexir venom series 8gb (2x4gb) ddr3 pc3-12800c9 1600mhz dual channel memory kit (avd3u16000904g-2cig) - green light @ £39.95 inc vat
avexir venom series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. the venom series is developed by avexir r&d team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
avexir core venom series is extremely unique as its most likely the only ram in the world which uses strobe/pulsating led's. even more unique is that the venom series are green in colour, making them look absolutely amazing, plus a perfect match for gigabyte sniper boards.
avexir strictly adheres to quality standards set by jedec (the joint electron devices engineering council) and iso9001.</p>
features:
- black pcb
- green led strobe lighting effect
- cas timings: 9-9-9-24
- lifetime warranty
was [£59.99] inc. vat
order now
crucial ballistix sport 8gb (2x4gb) ddr3 pc3-12800c9 1600mhz dual channel kit (bls2cp4g3d1609ds1s00ceu) @ £32.99 inc vat
overclockers uk brings you one of the most notable names in system memory today.
these high performance modules are engineered to deliver the fastest, most reliable memory for gaming and performance enthusiasts. upgrading has never been this easy!
if you‘re new to performance memory and like what ballistix has to offer, the crucial ballistix sport series is a great place to start. this line was created for mainstream users and general enthusiasts. they feature heat spreaders for thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility.
this memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade, ideal for any intel sandybridge or amd am3 based system.
- pc3-12800 1600mhz cas 9-9-9-27
- designed for entry-level & mainstream users
- integrated heat spreaders
- 1.5v vdimm
- dual channel memory kit, ideal for any intel sandybridge or amd am3 based system
- limited lifetime warranty
- sandybridge/ivybridge compatible
was [£35.99] inc. vat
only £32.99 inc vat.
order now
crucial ballistix sport 16gb (2x8gb) ddr3 pc3-12800c9 1600mhz dual channel kit (bls2cp8g3d1609ds1s00ceu) @ £62.99 inc vat
- 1.5v vdimm
was [£68.99] inc. vat
only £62.99 inc vat.
order now
avexir blitz 1.1 original 8gb (2x4gb) ddr3 pc3-19200c10 2400mhz dual channel memory kit (avd3u24001004g-2bz1) @ £59.99 inc vat
the highly anticipated blitz 1.1 is specifically designed for gamers and overclockers alike for extreme overclocking performance. the concept of blitz 1.1 not only extends the fantastic led light hue from the core series but also with extraordinary design for heatspreader. the aluminium extrusion technique is deployed on every blitz 1.1 module and together with its uncompromising design style; the blitz 1.1 is ready for outstanding gaming and overclocking potential. blitz also employs self-assembled, adjustable heat sink spreaders; gamers can uninstall external heat sink for ultimate performance.
this is the ordinary and classic design. with rich red and black heat sink as base, the avexir logo is carved on the side and covered with alabaster white led on the top. it's like the sharpest sword waiting and readying to fight for the forces from the dark side. this is aligned with avexir's values, when its ready then we are momentum.
the avexir brand is an established manufacturer associated with producing top quality, high-end ram memory. avexir is one of the only manufactures in which the factories hand check each module when it comes to overclocking and working in dual and quad channel modes. the modules are packed into elegant boxes only when they pass thorough quality control tests on different systems including amd and intel processors. other manufacturers unfortunately don’t do such controlled hand quality checks, which means users are more likely to encounter a faulty ddr module, which can cause incompatibilities and headache for the user.
new avexir blitz 1.1 original in our oppinion is the absolute best looking memory in the market today. this ram simply looks truly amazing with a truly unique design with its white leds which pulsate and can really set your system apart from others making it truly unique.
features:-
- black pcb
- blitz 1.1 original high performance heatspreaders
- white led strobe lighting effect
- speed: 2400mhz
- cas timings: 10-12-12-31
- voltage: 1.65v
- 100% tested in intel & amd based motherboards (only intel haswell mainboards for frequencies beyond 2400mhz)
- lifetime warranty
was [£79.99] inc. vat
only £59.99 inc vat.
order now
avexir blitz 1.1 original 16gb (2x8gb) ddr3 pc3-19200c10 2400mhz dual channel memory kit (avd3u24001008g-2bz1) @ £89.99 inc vat
features:-
- black pcb
- speed: 2400mhz
- voltage: 1.65v
- lifetime warranty
was [£155.99] inc. vat
only £89.99 inc vat.
order now
avexir blitz 1.1 original 32gb (4x8gb) ddr3 pc3-19200c10 2400mhz quad channel memory kit (avd3u24001008g-4bz1) @ £179.99 inc vat
features:-
- black pcb
- speed: 2400mhz
- voltage: 1.65v
- lifetime warranty
only £179.99 inc vat.
order now
avexir "sabranco" series 8gb (2x4gb) ddr3 pc3-19200c11 2400mhz dual channel memory kit - white light @ £49.99 inc vat
a product never meant for production as was just a showcase product by avexir. but the combined powers of overclockers uk and caseking group means avexir have agreed to produce this absolutely stunning memory kit for us. of course this memory will work with any ddr3 mainboard but is a perfect match for the asus z97 sabertooth sabranco motherboard which we also sell.
this memory has incxredible performance also being c11 and 2400mhz makes this one incredibly fast and highly efficient memory kit. remember avexir is an exclusive brand and only available from ocuk and caseking in europe and we regard it as some of the very best memory on the market today with completely unique styling and the highest quality packaging on the market right now.
features:-
- black pcb
- core original high performance sabranco heatspreaders
- speed: 2400mhz
- cas timings: 11-13-13-31
- voltage: 1.65v
- lifetime warranty
only £49.99 inc vat.
order now
avexir "sabranco" series 16gb (2x8gb) ddr3 pc3-19200c11 2400mhz dual channel memory kit - white light @ £89.99 inc vat
features:-
- black pcb
- speed: 2400mhz
- voltage: 1.65v
- lifetime warranty
was [£119.99] inc. vat
order now
asus radeon r9 390 dc3 oc strix 8192mb gddr5 pci-express graphics card @ £281.99 inc vat
taken from the ancient roman and greek word for owl, strix means the keenest hearing and sharpest eyesight. strix means feeling your environment so that you detect and react to the slightest movement. strix means survival on the very edge of instinct. strix is in your blood, as it is in ours.
asus strix r9 390x gaming graphics cards packed with exclusive asus technologies, including directcu iii with triple wing-blade 0db fan design for maximum air flow with 30% cooler and 3x quieter performance. this card features exclusive asus auto-extreme technology with super alloy power ii for premium aerospace-grade quality and reliability. it also has gpu tweak ii with xsplit gamecaster, provides intuitive performance tweaking and lets you stream your gameplay instantly.
exclusive directcu iii cooling technology features two exclusive 10 mm direct-gpu contact heat-pipes that transports 40% more heat away from the gpu and outperform reference designs, achieving up to 30% cooler gaming performance.
directcu iii features triple 0db fans engineered with a patented, new wing-blade design that delivers maximum air flow and improved 105% static pressure over the heat sink, while operating at 3x quieter volumes than reference cards. the 0db fans also let you enjoy games like league of legends® and starcraft® in complete silence — because the fan stops completely when the gpu temperature remains below a set level*. this makes directcu iii the coolest and quietest graphics card in the market.
all asus graphics cards are now produced using auto-extreme technology, an industry-first, 100% automated production process that incorporates premium materials to set a new standard of quality. auto-extreme technology ensures consistent graphics card quality as well as improved performance and longevity. this new manufacturing process is also environmentally friendly, eliminating harsh chemicals and reducing power consumption by 50%.
asus engineers have integrated aerospace-grade alloy components into their graphics card designs to reinforce overall reliability. super alloy power ii components greatly enhance efficiency, reduce power loss, provide 2x reduced component buzzing while under full load, and achieve thermal levels that are approximately 50% cooler than previous designs.
redesigned with an intuitive, all-new ui, gpu tweak ii makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. with one click, the new gaming booster function maximizes system performance by removing redundant processes and allocating all available resources automatically. xsplit gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
specification:-
- gpu: grenada pro
- stream processors: 2560
- core speed: 1050mhz
- memory speed: 6000mhz
- memory interface: 512-bit
- memory capacity: 8192mb gddr5
- pci-express x16 lane required
- 600w or greater psu required
- power connectors: 1x 8-pin & 1x 6-pin required
- display outputs: 1x dual link dvi, 1x hdmi, 3x displayport
- warranty: 3yr
was [£289.99] inc. vat
only £281.99 inc vat.
order now
asus geforce gtx 980ti dc3 oc strix 6144mb gddr5 pci-express graphics card (gtx980ti-6gd5) @ £581.99 inc vat
asus strix gtx 980ti is an all-new gaming graphics card packed with exclusive asus technologies, including directcu iii with triple patented wing-blade 0db fan design delivers max air flow with 30% cooler and 3x quieter performance; 0db fan technology for light gameplay in total silence; and blu-ray movie playback that's free from distracting background noise.
asus strix-gtx980ti-dc3oc-6gd5-gaming with factory-overclocked 1291mhz gpu boost clock and 7200mhz memory speed. and also, 1317mhz gpu boost clock in oc mode provides better gaming experience. the cards with exclusive 12+2 phase auto-extreme technology with super alloy power ii which is premium aerospace-grade quality and reliability. asus graphics cards are produced using auto-extreme technology, an industry-first 100% automated production process, feature aerospace-grade super alloy power ii components for unsurpassed quality and reliability.
asus strix-gtx980ti-dc3oc-6gd5-gaming armored with an advanced backplate prevents pcb bending over time, and now includes gpu-fortifier, which relieves physical stress around the gpu in order to protect it. asus graphics cards also equipped pulsating strix led to make a statement while adding style to your system with new pulsing light effects.
asus graphics cards bundled with gpu tweak ii with xsplit gamecaster provides intuitive performance tweaking and lets you stream your gameplay instantly. what's more, streaming or recording your gameplay with free 1-year premium xsplit gamecaster (usd 99.95 /yr) lets users share gameplay live. all the cards come equipped with 3x displayport interface to support 4k resolution surround.
features:
- vr ready
- directx 12 ready
- 4k ready
- 6144mb vram
specification
- geforce 980ti
- gpu: geforce 980ti
- core base clock: 1216mhz
- core boost clock: 1317mhz
- memory clock: 7200mhz
- memory size: 6144mb gddr5
- bus type: pci express 3.0
- memory bus: 384-bit
- cuda cores: 2816
- directx 12: yes
- dvi port: 1x dual-link dvi, 3x displayport & 1x hdmi
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 2x 8-pin
- 600w psu required
- 250w tdp
- warranty: 3yr
was [£589.99] inc. vat
only £581.99 inc vat.
order now
evga geforce gtx 980ti hybrid 6144mb gddr5 pci-express graphics card (06g-p4-1996-kr) @ £629.99 inc vat
ti. the most powerful two letters in the world of gpus. when paired with our flagship gaming gpu–geforce gtx 980–it gives you incredible new levels of performance and capabilities. gtx 980 ti is accelerated by the groundbreaking nvidia maxwell™ architecture to deliver an unbeatable 4k and virtual reality experience. with 2816 nvidia® cuda® cores and 6 gb of memory, it has the horsepower to drive whatever comes next.
features:
- vr ready
- directx 12 ready
- 4k ready
- 6144mb vram
- titan x pcb
specification
- geforce 980ti
- core base clock: 1140mhz
- core boost clock: 1228mhz
- memory clock: 7010mhz
- cuda cores: 2816
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 1x 6-pin & 1x 8-pin
- 600w psu required
- 250w tdp
- dimensions: l=282mm, w=110mm, h=43mm
- warranty: 3yr (product registration required!)
was [£659.99] inc. vat
only £629.99 inc vat.
order now
kfa2 geforce gtx 980ti "hall of fame wc edition" 6144mb gddr5 pci-express graphics card (98irh5dhh3wt) @ £709.99 inc vat
kfa2 hall of fame edition cards are born from top quality components and exemplary innovation to achieve one sole objective—to break records. the kfa2 gtx 980 ti hof exemplifies this and sets the definitive standard as the world’s best gtx 980 ti graphics card.
working in-conjunction with bitspower, kfa2 has developed a water cooling solution designed to fully unleash the raw potential of the gtx 980ti hof graphics cards with the unprecedented cooling capacity needed for extreme overclocks.
features:
- vr ready
- directx 12 ready
- vr ready
- 6144mb vram
- custom waterloop cool required!
specification
- geforce 980ti
- core base clock: 1203mhz
- core boost clock: 1304mhz
- cuda cores: 2816
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 2x 8-pin
- 600w psu required
- 250w tdp
- warranty: 2yr
was [£749.99] inc. vat
only £709.99 inc vat.
order now
inno3d geforce gtx 980ti x3 ultra 6144mb gddr5 pci-express graphics card (c98t3-1sdn-n5hnx) @ £499.99 inc vat
features:
- vr ready
- directx 12 ready
- 4k ready
- 6144mb vram
- titan x pcb
specification
- geforce 980ti
- core base clock: 1152mhz
- core boost clock: 1241mhz
- cuda cores: 2816
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- 600w psu required
- 250w tdp
- warranty: 3yr
- review at eteknix: http://www.eteknix.com/inno3d-ichill-x3-ultra-geforce-gtx-980ti-graphics-card-review/
- review at hexus: http://hexus.net/tech/reviews/graphics/84497-inno3d-geforce-gtx-980-ti-ichill-x3-ultra/
- review at toms hardware: http://www.tomshardware.de/inno3d-gtx-980-ti-ichill-airboss-grafikkarte,testberichte-241842.html
Was [£529.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
MSI GeForce GTX 980Ti Gaming 6144MB GDDR5 PCI-Express Graphics Card (GTX 980 Ti Gaming 6G) @ £539.99 inc VAT
Ti. The most powerful two letters in the world of GPUs. When paired with our flagship gaming GPU–GeForce GTX 980–it gives you incredible new levels of performance and capabilities. GTX 980 Ti is accelerated by the groundbreaking NVIDIA Maxwell™ architecture to deliver an unbeatable 4K and virtual reality experience. With 2816 NVIDIA® CUDA® cores and 6 GB of memory, it has the horsepower to drive whatever comes next.
Features:
- VR Ready
- DirectX 12 Ready
- 4k Ready
- 6144MB VRAM
Specification
- GeForce 980Ti
- GPU: GeForce 980Ti
- Core Base Clock: 1178MHz
- Core Boost Clock: 1279MHz
- Memory Clock: 7100MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2816
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 250W TDP
- Dimensions: L=282mm, W=110mm, H=43mm
- Warranty: 3yr
Was [£559.99] Inc. VAT
Only £539.99 inc VAT.
ORDER NOW
Zotac GeForce GTX 980Ti "Reference Design" 6144MB GDDR5 PCI-Express Graphics Card (ZT-90501-10P) @ £499.99 inc VAT
Features:
- VR Ready
- DirectX 12 Ready
- 4k Ready
- 6144MB VRAM
- Titan X PCB
- Titan X Cooler (Silver shroud)
Specification
- GeForce 980Ti
- Core Base Clock: 1000MHz
- Core Boost Clock: 1075MHz
- Memory Clock: 7010MHz
- CUDA Cores: 2816
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin & 1x 8-Pin
- 600W PSU Required
- 250W TDP
- Warranty: 5yr (Product Registration Required!)
ORDER NOW
Asus GeForce GTX 970 TURBO OC 4096MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
ASUS Turbo GTX 970 is a special-edition graphics card with distinctive white coloring. Featuring an innovative modern dual-intake blower, ASUS Turbo GTX 970 features a 10% larger heat-dissipation area for 10% cooler performance and superior SLI configurations. It also comes equipped with a dual ball-bearing fan for a 4X longer card lifespan and exclusive Super Alloy Power components for superior stability. The included easy-to-use GPU Tweak tuning tool enables you to squeeze every last drop of performance out of Turbo GTX 970, and FREE 1-year premium license XSplit Gamecaster lets you stream or record your gameplay. The latest in a long line of industry innovations, ASUS Turbo GTX 970 represents yet another pinnacle in the pursuit of the perfect graphics card.
Features:
- Exclusive Dual-intake blower design - with 10% larger dissipation area delivers 10% cooler, Vastly quieter performance.
- Dual-ball bearing fan - Without the problem of oil drying common in sleeve-bearing fans, the Dual-ball bearing fan on ASUS Turbo GTX 970 lasts 4X longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency.
- Super Alloy Power -Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation.
- GPU TWEAK + XSplit Gamecaster - easily stream and real-time intuitive graphics tuning and monitoring.
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1088MHz
- Core Boost Clock: 1228MHz
- Memory Size: 4096MB GDDR5
- Memory Bus: 256-bit
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin
- 450W PSU Required
- 225W TDP
- Warranty: 3yr
Was [£275.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 970 WindForce OC 4096MB GDDR5 PCI-Express Graphics Card (GV-N970WF3OC-4GD) @ £254.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 970
- Core Base Clock: 1114MHz
- Core Boost Clock: 1253MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Was [£259.99] Inc. VAT
Only £254.99 inc VAT.
ORDER NOW
MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £275.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1140MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Was [£299.99] Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
Zotac GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card (ZT-90101-10P) @ £239.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1076MHz
- Core Boost Clock: 1216MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 145W TDP
- Warranty: 5yr (2yr +3yr FREE when you register the product with Zotac within 28 days of purchase)
Was [£249.95] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 960 OC 4096MB GDDR5 PCI-Express Graphics Card (GV-N960OC-4GD) @ £155.99 inc VAT
The GeForce® GTX™ 960 delivers incredible performance, power efficiency, and cutting-edge gaming technologies that only NVIDIA Maxwell™ technology can offer.
This is the perfect upgrade to advanced gaming, letting you dominate the competition with 60% faster performance and twice the power efficiency than previous-generation cards*. Unleash its massive overclocking potential and push your performance even further. Plus, it features VXGI for realistic lighting, support for smooth, tear-free NVIDIA G-SYNC™ technology, and Dynamic Super Resolution that enables 4K-quality gaming on 1080p displays.
The GTX 960 even gives you great gaming to go with NVIDIA GameStream™ technology that lets you stream PC games to NVIDIA SHIELD™ devices. *Compared to GeForce GTX 660.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- GPU: GeForce GTX 960
- Core Base Clock: 1216MHz
- Memory Bus: 128-bit
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 3yr
Was [£158.99] Inc. VAT
Only £155.99 inc VAT.
ORDER NOW
MSI GeForce GTX 780 Lightning 3072MB GDDR5 PCI-Express Graphics Card @ £185.99 inc VAT
MSI, world renowned graphics card and motherboard manufacturer, has officially announced the release of the GeForce GTX 780 LIGHTNING. This product uses the new exclusive Triple Force Architecture and is equipped with a Triple Level signals LED. The card, from the inside out, represents the next revolution thermal design. The combined power of the Twin BIOS and the card's Enhanced Power Design equip gamers and extreme overclockers with the best graphics card. This superior performance is accompanied by a 20-phase power design that can unlock the limitless potential of the graphics card. Also featuredis the patented GPU Reactor powered back plate design which filters power supply noise and improves overclocking stability. The MSI GeForce GTX 780 LIGHTNING is built using Military Class 4 components that have passed rigorous certification testing in laboratories. With such powerful components, this graphics card is guaranteed to have an impressive service life and excellent overclocking stability. Additionally, the popular 3x3 OC Kits allow for gamers to effectively monitor the status of the graphics card. MSI products are renowned for leading the industry due to the company's innovative R&D, excellent performance, streamlined thermal design, and quality components and software. The MSI GeForce GTX 780 LIGHTNING is once again the most powerful graphics card.
The latest generation of MSI's GeForce GTX 780 LIGHTNING uses Triple Force Architecture. Equipped with a Triple Level Signals LED function, TriFrozr Thermal Design with independent fan control system, and PureDigital PWM control. The Triple Level Signals LED features green, blue, and red lights that represent light, medium and heavy power loads on the device. This ensures that players have complete control over their games or the overclocking process. The innovative TriFrozr Thermal Design with independent fan control far exceeds any traditional or custom cooler's thermal performance and ensures better cooling of the GPU, memory and PWM modules. This iteration of MSI's exclusive design builds upon the PropellerBlade and the Dust Removal Technology of the previous model, alongside seven 8 mm SuperPipes for unrivaled thermal performance. In addition, the PureDigital PWM control technology provides a more stable and accurate voltage signal than traditional designs. The PWM's reaction time is shorter and helps enthusiasts more achieve a higher stability in the most stressful of environments.
Twin BIOS is composed of an original BIOS and overclocking BIOS. The original BIOS allows users to obtain better performancethrough out of the box overclocking, while the overclocking BIOS is specifically designed for extreme LN2 overclocking. By removing restrictions, the capabilities of the graphics card are dramatically increased, which allows users to unlock the card's full potential. The enhanced power supply provides more phases of power than standard models. The GPU has 16 phases, which more than doubles the capabilities of standard designs. The memory of the power supply even has a independent power source, which further supports a foundation for extreme overclocking. Not to mention that MSI's exclusive, patented GPU Reactor filters out extra noise for a stable overclocking experience.
MSI always emphasizes top quality and stability when pursuing the highest in product performance. When developing products, MSI makes satisfying market demands and expectations its primary purpose. The MSI GeForce GTX 780 LIGHTNING introduces the latest Military Class 4 components to the series. The components have gone through rigorous testing in a laboratory to satisfy the Military Standard 810G. Regardless if it is the advantages of the low-temperature, high performance DrMOS 4, the double-sided CopperMOS thermal design, the highly durable and stable tantalum Hi-C Cap cores, the polished surface of the New SFC for added cooling, or the corrosion proof Dark Solid CAP, each aspect of the LIGHTNING ensures the best possible stability.
Designed specifically for overclocking, the 3x3 OC Kits are a must-have for all enthusiasts. The kit allows users to adjust the voltage levels GPU, memory, and PLL through MSI's exclusive Afterburner utility while monitoring GPU, memory, and MOFSET temperatures. V-Check Points also capitalize upon the multi meter measuring of GPU, memory, and PLL voltage levels to give users direct calibration data-a function that guarantees success in the world of extreme overclocking.
Features:
- 16+3+1 (20) Phase Power
- Propeller Blade Technology
- 8 SuperPipes and dense aluminium fins to maximize thermal dissipation
- LN2 Mode
- Triple level signals show the real-time load with different colours
- TriFrozr Thermal Design - Three PWM fans with independent control on the most advanced thermal design.
- Pure digital PWM Control - Digital GPU / Memory / AUX voltages
- Twin BIOS
- Enhanced Power - 16 GPU phases and 3 memory Phases on a custom designed 10 layers PCB for amazing overclocking potential.
- GPU Reactor for improved OC ability providing 300% higher power capacity and reduces power noise (ripple)
- MIL-STD-810G standard certified to ensure the best stability and quality.
- Uses DrMOS 4, CopperMOS, Hi-c CAP, new SFC and Dark Solid CAP.
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 980 MHz
- Core Boost Clock: 1033 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- Warranty: 2yr
Was [£199.99] Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
MSI Geforce GTX 780 Gaming Edition OC 6144MB GDDR5 PCI-Express Graphics Card @ £229.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 6GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Features:-
- Gigantic 6GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- Core Base Clock: 954 MHz
- Core Boost Clock: 1006 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Was [£239.99] Inc. VAT
Only £229.99 inc VAT.
ORDER NOW
MSI GeForce GTX 780Ti Gaming Edition LE 3072MB GDDR5 PCI-Express Graphics Card @ £229.99 inc VAT
A graphics card is the single most important element for more FPS. As gamers, we understand that not just any graphics card "will do". That's why we bring you the best of the best. We don't want to bug you with noise and heat, but we DO want to give you more performance. With MSI GAMING series graphics cards you get just that.
Most MSI Gaming graphics cards come pre-overclocked out of the factory. This simply means you get more performance out of your card, without spending any time on checking for maximum clocks and stability. Pre-overclocked graphics cards simply give more performance and you don't have to worry about damaging your card, it is completely covered by our warranty!
MSI's Twin Frozr has been the industry defining graphics card cooler. The first Twin Frozr kicked of the dual-fan trend and today MSI stays true to its dual-fan dual-slot design where others have to resort to less effective means.
The other part that the Twin Frozr cooler uses is a large Aluminium fin grid array that provides a huge amount of surface area for cooling. Heat from the GPU is transferred to the fin grid array by virtue of heat pipes with MSI's special SuperPipe technology. SuperPipes transfer heat twice as fast as regular heat pipes enabling an MSI GAMING graphics card to stay cooler than the competition.
Futhermore, MSI provide all new Airflow Control technology on Twin Frozr. This new thermal tech. is leading airflow to heat pipe by spcial deflector on heatsink, so it can deflect more airflow to heat pipes directly. In addtion,This exclusive heatsink design is increasing the area of heatsink so that enhancing the efficiency of dissipation much more.
One of the deciding factors in performance is the quality of the components used. That is why MSI only uses MIL-STD-810G certified components for its Gaming cards because only these components have proven to be able to withstand the torturous circumstances of extreme gaming and overclocking.
One With their aluminum core design, Solid CAP's have been a staple in high-end design mainboard designs and provides lower Equivalent Series Resistance (ESR) as well as its over-10-year lifespan. A Hi-c CAP is a very small, but super-efficient capacitor. Besides ensuring enough spacing around a CPU socket to install large coolers, it also allows for 93% energy efficiency. Thanks to Hi-c CAP's MSI mainboards are the most energy efficient in the market. It’s a new generation, form-in-one choke, which doesn’t generate vibration noise under heavy loading & provide 37,5% higher current output comparing with traditional ring chock. It’s very important when GPU is overclocked or under high loading, since it requires even more amount of electricity which can be provided through this component.
Specification:-
- GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 902MHz
- Core Boost Clock: 967MHz
- Memory Clock: 7000MHz
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
ORDER NOW
MSI Geforce GTX 770 Gaming Edition 2048MB GDDR5 PCI-Express Graphics Card @ £119.99 inc VAT
MSI's Gaming Edition GTX 770 looks absolutely stunning with the black and red styling. The cooling is the latest Twin FrozR design which is designed to not only reduce temperatures further but also noise levels as well. So you can enjoy the latest games such as Titanfall with smooth frame rates and in complete silence too.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1046MHz (GK104)
- Core Boost Clock: 1085MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2118MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 2 x 8-Pin PCI-E Connectors required
- Warranty: 2 Years
Was [£125.99] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
MSI Geforce GTX 770 Gaming Edition OC 2048MB GDDR5 PCI-Express Graphics Card @ £124.99 inc VAT
Features:-
Specification:-
- Core Clock: 1059MHz (GK104)
- Core Boost Clock: 1111MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was [£129.95] Inc. VAT
Only £124.99 inc VAT.
ORDER NOW
MSI Geforce GTX 770 Lightning 2048MB GDDR5 PCI-Express Graphics Card @ £129.95 inc VAT
The GeForce® GTX 770 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Features:-
Specification:-
- Core Clock: 1150MHz (GK104)
- Core Boost Clock: 1202MHz
- Shader Clock: 2300MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 250 watts at stock speed)
- 2x 8-Pin PCI-E Connectors required
- Warranty: 2 Years
Was [£139.99] Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU) @ £74.99 inc VAT
nonl2br
<b>Specifications</b>
<ul>
<li>Controller: Samsung MGX Controller
<li>DRAM Cache Memory: 512MB
<li>Sequential Read: 540Mbps
<li>Sequential Write: 520Mbps
<li>4KB Random Read (QD1): Max 10,000 IOPS
<li>4KB Random Write (QD1): Max 40,000 IOPS
<li>4KB Random Read (QD32): Max 97,000 IOPS
<li>4KB Random Read (QD32): Max 88,000 IOPS
<li>Reliability: MTBF: 1.5 million hours
<li>Warranty: 5 Years
<li>TBW: 75TBW
<li>Data Security: AES 256-bit Full Disk Encryption (FDE) / TCG/Opal V2.0 Encrypted Drive (IEEE1667)
</ul>
<b>3D V-NAND Technology and THE SAMSUNG SSD 850 EVO</b>
<p>Samsung’s unique and innovative 3D V-NAND flash memory architecture is a breakthrough in
overcoming the density limitations, performance and endurance of today’s conventional planar NAND architecture. 3D VNAND is fabricated by stacking 32 cell layers vertically over one another rather than
decreasing the cells dimensions and trying to fit itself onto a fixed horizontal space resulting in
higher density and better performance utilizing a smaller footprint.</p>
<p>The 850 EVO is the advanced consumer SSD powered by 3D V-NAND technology that maximizes everyday computing experiences with optimized performance and enhanced reliability.</p>
<b>Optimized performance for everyday computing experiences</b>
<p>Powered by Samsung's cutting-edge 3D V-NAND technology, 850 EVO delivers top-class sequential
and random read and write performance to optimize everyday computing. With improved performance thanks to TurboWrite technology the 850 EVO provides not only more than a 10% better user experience than 840 EVO but up to 1.9x faster random write speeds for the 120/250 GB models as well. In fact, the 850 EVO delivers top class sequential read (540 MB/s) and write (520 MB/s) performance in all capacities. This comes with optimized random read and write performance on all QD and improved QD1 and QD2 random performance for Client PC usage.</p>
<b>Reinforcement of TurboWrite Technology</b>
<p>In the early stages of the 840 EVO, Samsung adopted sequential write performance first. With
TurboWrite, write speeds are significantly accelerated during data transfers by creating a high-performance write buffer in the SSD. If a consecutive write operation (i.e. no idle time) exceeds the size of the buffer, the transfer will exit TurboWrite and be processed at ”After TurboWrite” speeds. Once the buffer is cleared, TurboWrite performance will resume. However, the buffer size for TurboWrite is more than sufficient for everyday PC use, and you should experience accelerated speeds for most workloads. </p>
<p>For the 850 EVO, enhanced TurboWrite technology applied to random write speeds up to 1.9x faster for the 120 GB model and 1.25x faster for the 250GB model over the 840 EVO.</p>
<b>Guaranteed endurance and reliability for maximum use</b>
<b>Guaranteed endurance</b>
<p>The 850 EVO delivers guaranteed endurance and reliability by doubling the TBW compared to the
previous generation 840 EVO backed by an industry leading 5 year warranty. With twice the endurance of a typical NAND flash SSD, the 850 EVO will keep working as long as you do. The 850 EVO guarantees a 5 year limited warranty or 75TBW for 120GB and 250GB, 150TBW for 500GB and 1TB.</p>
<b>Enhanced reliability with improved sustained performance</b>
<p>With enhanced reliability through improved sustained performance, the 850 EVO assures longterm
dependable performance up to 30% longer than the 840 EVO with minimized performance degradation. This means you can use it every day when taking care of work or entertaining yourself knowing it will keep performing even with heavy daily workloads over the years.</p>
<b>Advanced data encryption</b>
<p>The 850 EVO provides the same data encryption feature as the 840 EVO does. Self-Encrypting Drive
(SED) security technology will help keep data safe at all times. It includes an AES 256-bit hardwarebased
encryption engine to ensure that your personal files remain secure. Being hardwarebased, the encryption engine secures your data without performance degradation that you may experience with a software-based encryption. Also, 850 EVO is compliant with advanced security management solutions (TCG Opal and IEEE 1667). Magician will guide ”How to use security features”. Furthermore, you can erase or initialize data with the crypto erase service with PSID.</p>
<b>Efficient power management for all PC applications</b>
<p>Power consumption affects everyone. You actually save of up to 50% more on power than
with the 840 EVO during write operations thanks to 3D V-NAND consuming half the power of 2D
planar NAND. </p>
<p>Plus, whether it’s preserving battery life for longer cordless use or just saving on costs, power
management is important. Device sleep signals the SSD to enter a low power state which is vital for
ultra-books and other battery powered devices. With 850 EVO’s Device Sleep at a highly efficient
2mW you get longer battery life on your notebook thanks to a controller optimized for 3D V-NAND.
With the 850 EVO you can work and play longer without having to plug in.</p>
<b>Summary</b>
<ul>
<li>SATA 6Gb/s SSD for Client PCs
<li>2.5 inch form factor
<li>Samsung 32 layer 3D V-NAND
<li>Samsung Magician Software for SSD management
<li>Samsung Data Migration Software
</ul>
Was [£82.99] Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
Samsung 1.0TB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E1T0B/EU) @ £259.99 inc VAT
nonl2br
<ul>
<li>Controller: Samsung MEX Controller
<li>DRAM Cache Memory: 1GB
<li>4KB Random Read (QD32): Max 98,000 IOPS
<li>4KB Random Read (QD32): Max 90,000 IOPS
<li>TBW: 150TBW
</ul>
planar NAND. </p>
<b>Summary</b>
<ul>
</ul>
Was [£269.99] Inc. VAT
ORDER NOW
Great Deals ending next Wednesday!
features:
specification:
- led backlit
- height adjustable
- vesa compliant
order now
specifications:-
- screen type: va
- backlight: led
- vga port(s): 1
- dvi port(s): 1
- hdmi port(s): 1
order now
specification:-
- diagonal: 24"
- panel: tn led
- hdcp: yes
- weight: 5.5 kg
order now
specification:-
- monitor size: 27"
- colors: 16.7 m
- weight: 7.5 kg
order now
specification:-
- panel type: tn
- pip/pbp support
- speakers: yes
order now
specification:-
- panel: tn
- usb 3.0 hub
- freesync enabled
- weight: 6.1 kg
- warranty: 3yr
order now
features:
- black pcb
order now
features:
- black pcb
order now
features:
- black pcb
order now
features:
- black pcb
order now
features:
- black pcb
order now
features:
- black pcb
order now
features:
- black pcb
- lifetime warranty
order now
features:
- black pcb
- lifetime warranty
order now
features:
- black pcb
- lifetime warranty
order now
- 1.5v vdimm
order now
- 1.5v vdimm
order now
features:-
- black pcb
- speed: 2400mhz
- voltage: 1.65v
- lifetime warranty
order now
features:-
- black pcb
- speed: 2400mhz
- voltage: 1.65v
- lifetime warranty
order now
features:-
- black pcb
- speed: 2400mhz
- voltage: 1.65v
- lifetime warranty
order now
features:-
- black pcb
- speed: 2400mhz
- voltage: 1.65v
- lifetime warranty
order now
features:-
- black pcb
- speed: 2400mhz
- voltage: 1.65v
- lifetime warranty
order now
specification:-
- gpu: grenada pro
- warranty: 3yr
order now
features:
- vr ready
- directx 12 ready
- 4k ready
- 6144mb vram
specification
- geforce 980ti
- cuda cores: 2816
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 2x 8-pin
- 600w psu required
- 250w tdp
- warranty: 3yr
order now
features:
- vr ready
- directx 12 ready
- 4k ready
- 6144mb vram
- titan x pcb
specification
- geforce 980ti
- cuda cores: 2816
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- 600w psu required
- 250w tdp
order now
features:
- vr ready
- directx 12 ready
- vr ready
- 6144mb vram
specification
- geforce 980ti
- cuda cores: 2816
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 2x 8-pin
- 600w psu required
- 250w tdp
- warranty: 2yr
order now
features:
- vr ready
- directx 12 ready
- 4k ready
- 6144mb vram
- titan x pcb
specification
- geforce 980ti
- cuda cores: 2816
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- 600w psu required
- 250w tdp
- warranty: 3yr
ORDER NOW
Features:
- VR Ready
- DirectX 12 Ready
- 4k Ready
- 6144MB VRAM
Specification
- GeForce 980Ti
- CUDA Cores: 2816
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 250W TDP
- Warranty: 3yr
ORDER NOW
Features:
- VR Ready
- DirectX 12 Ready
- 4k Ready
- 6144MB VRAM
- Titan X PCB
Specification
- GeForce 980Ti
- CUDA Cores: 2816
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 600W PSU Required
- 250W TDP
ORDER NOW
Features:
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin
- 450W PSU Required
- 225W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 145W TDP
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 3yr
ORDER NOW
Features:
- LN2 Mode
- Twin BIOS
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- Warranty: 2yr
ORDER NOW
Features:-
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
ORDER NOW
Specification:-
- GeForce GTX 780Ti
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
ORDER NOW
Features:-
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
ORDER NOW
Features:-
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
ORDER NOW
Features:-
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
ORDER NOW
nonl2br
<ul>
<li>TBW: 75TBW
</ul>
planar NAND. </p>
<b>Summary</b>
<ul>
</ul>
ORDER NOW
nonl2br
<ul>
<li>TBW: 150TBW
</ul>
planar NAND. </p>
<b>Summary</b>
<ul>
</ul>
ORDER NOW
