AOC Q2577PWQ Input lag?
5 Nov 2005
Hi all,
The AOC Q2577PWQ is on offer this week and looks very good value, I'm just concerned about input lag as its a bit higher then the Dell U2515H, should I worry....? Is the Dell worth the extra cash?
I have a old NEC 20WGX at the moment and that seems fine but no idea on input lag.....
im thinking same thing just watched a youtube video ,and it seems it as bad input lag. but if its the same panel as the dell 25 inch or the 25 inch acer it should be fine. should i this. or buy the dell or acer.
mines on its way today ass well, should be here soon. let me know if you have any problems with yours,
Mine came and seems perfect to me!! I did a black and white screen test and seems fine...maybe a little bit of IPS glow in top left but no issue as I'm used to IPS displays....My old NEC was a bit glowtasitc....this is 1000% better!
Good luck with the box its a nightmare!
Is yours rev A01 ?
With mine the bleed was so severe at the bottom left. Even showed up in a well lit room. 2 of them had uneven colours, one half of the screen had a yellow tint.
mine arrived last night. but with no original box, so theres no rev number, but it is as new condition,works perfect, not bad for £210
