** CYBER MONDAY COMES EARLY: CRAZY MONITOR DEALS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK the theme continues, now we move to monitors!!!
Asus VS197DE 18.5" 1366x768 TN LED Monitor - Black @ £59.99 inc VAT
Delicate touches make a monitor truly great, VS197D LED monitor with 50,000,000:1 high contrast ratio, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images.
Specification:-
- Panel Size: Wide Screen 18.5"(47.0cm) 16:9
- True Resolution : 1366x768
- Pixel Pitch : 0.3mm
- Brightness(Max) : 200 cd/m
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 5ms
- Display Colors : 16.7M
- Connections: 1x Analogue
- Kensington lock
- Phys. Dimension with Stand (WxHxD) : 447x346x185mm
- Warranty: 3yr (On-Site with Asus - 01442 265 548)
Was [£71.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Asus VS228DE 22" 1920x1080 TN Widescreen LED Monitor - Black @ £68.99 inc VAT
VS228DE Full HD LED monitor, with 50,000,000:1 high contrast ratio, is optimized for the finest image and colour quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Key Features:-
- True-to-life Pictures Powered by LED
- Full HD 1080p Support
- Versatile viewing positions with Smart View Technology
- Aspect Control function
- Splendid Video Intelligence Technology
Specifications:-
- Screen Size: 21.5"
- Screen Type: LCD
- Backlight: LED
- Aspect Ratio: 16:9
- Recommend Resolution: 1920 x 1080
- Screen Features: Full HD
- Colours: 16.7 Million
- Pixel Pitch: 0.248mm
- Horizontal Frequency Range: 30kHz - 80kHz
- Vertical Frequency Range: 55Hz - 75Hz
- Response Time: 5ms
- Contrast Ratio: 600:1
- Dynamic Contrast Ratio: 50,000,000:1
- Brightness: 200 cd/m²
- Max. Resolution: 1920 x 1080
- Horizontal Viewing Angle: 90°
- Vertical Viewing Angle: 65°
- Tilt Angle: -5°/20°
- VGA Port(s): 1
- Product Width: 556mm
- Product Height: 443mm
- Product Length: 130mm
- Input Power Source: Power Lead
- Normal Power Consumption: 21.1W
- Stand-by Power Consumption: 0.5W
- Wall Mount: VESA 100mm x 100mm
Was [£74.99] Inc. VAT
Only £68.99 inc VAT.
ORDER NOW
Asus VS229HA 22" 1920x1080 VA Widescreen LED Monitor - Black @ £89.99 inc VAT
Delicate touches make a monitor truly great, VS229HA Full HD LED monitor, with 80,000,000:1 high contrast ratio and full HDMI, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port.
VS229HA adopts 178°(H) / 178°(V) ultra wide viewing angle panel that eliminates color shift on your screen no matter where and how you look at it. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
Specifications:-
- Screen Type: VA
- Backlight: LED
- Vertical Frequency Range: 56Hz - 76Hz
- Response Time: 5ms (GTG)
- Contrast Ratio: 1000:1
- Dynamic Contrast Ratio: 80,000,000:1
- Brightness: 250 cd/m²
- Horizontal Viewing Angle: 178°
- Vertical Viewing Angle: 178°
- VGA Port(s): 1
- DVI Port(s): 1
- HDMI Port(s): 1
Was [£119.99] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Acer Predator XG270HUomidpx 27" 2560x1440 TN FREESYNC 144Hz Gaming Widescreen LED Monitor - Black/Red (UM.HG0EE.001) @ £287.99 inc VAT
The first FreeSync monitor available for pre-order, based on a very unique high performance TN panel designed for gaming with a 2560x1440 resolution, 144Hz, 1ms, Zeroframe and FreeSync support.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by AMD FREESYNC™ technology
Specification:-
- Screen Size: 27" (69cm)
- Resolution: 2560x1440 WQHD
- Panel: TN
- Response Time: 1ms
- Refresh Rate: 144Hz
- Brightness: 350cd/m
- Contrast ratio: 1000:1 (100,000,000:1 DCR)
- Connectivity: 1x DVI-D, 1x HDMI, 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- FreeSync Enabled
- Speakers: 2x2W Stereo
- Warranty: 2yr (Return to base with Acer - 0371 760 1000)
- Compatible with both NVIDIA & AMD Graphics Cards (FREESYNC Function only works with AMD cards)
Was [£319.99] Inc. VAT
Only £287.99 inc VAT.
ORDER NOW
Asus PG278Q ROG Swift 27" 2560x1440 TN G-Sync 144Hz Gaming Widescreen LED Slim Bezel Monitor - Black/Red @ £499.99 inc VAT
Quite possibly the best gaming monitor ever made and ideally suited to NVIDIA cards with 3D Vision 2.0 and G-Sync technology. This monitor runs at a staggering 2560x1440 resolution with 144Hz technology and a 1ms response, even better this is the latest in TN technology.
The ROG SWIFT PG278Q represents the pinnacle of gaming displays, seamlessly combining the latest technologies and design touches that gamers demand.
This 27-inch WQHD 2560 × 1440 gaming monitor packs in nearly every feature a gamer could ask for. An incredible 144Hz refresh rate and a rapid response time of 1ms eliminate lag and motion blur, while an exclusive Turbo key allows you to select refresh rates of 60Hz, 120Hz or 144Hz with just one press. The ROG SWIFT contains integrated NVIDIA® G-SYNC™ technology to synchronize the display's refresh rate to the GPU. This technology eliminates screen tearing, while minimizing display stutter and input lag to give you the smoothest, fastest and most breathtaking gaming visuals imaginable. Connectivity is simple, yet robust, with a single DisplayPort 1.2 port to enable NVIDIA® G-SYNC™ and dual USB 3.0 ports for convenience.
Conventional 60Hz monitors show extensive motion blur which detracts from your gaming experience. The ROG SWIFT PG278Q Gaming Monitor with NVIDIA® Ultra Low Motion Blur technology* reduces the effects of motion blur by delivering crisp edges in fast-paced gaming environments for perceivable differences in natural movement.
ASUS-exclusive GamePlus Technology enhances your gaming experience further by providing you with crosshair overlays for FPS games and multiple in-game timers for RTS/MOBA games.
The ROG Swift has a super-narrow 6mm bezel that begs this monitor to be used in multi-display gaming set-ups. With VESA wall mount capability and an ergonomic stand designed with full tilt, swivel, pivot and height adjustments, the ROG SWIFT is ready for long gaming sessions in comfort.
The ROG SWIFT PG278Q represents the next generation in gaming displays. This WQHD 2560 x 1440 monitor delivers four times the resolution of 720p, with 109 pixels per inch or 109 RGB matrices per inch. This gives you the benefits of greater image detail and up to 77% more onscreen desktop space than standard Full HD (1920 x 1080) displays. These minor details add up to give you a major in-game advantage.
Unlock the highest frame rates available, decimate lag and say goodbye to motion blur to gain the upper hand in first person shooters, racers, real-time strategy and sports titles. With twice the frame rate of standard LCDs, the ROG SWIFT PG278Q Gaming Monitor encourages you to never blink again.
Response time and ultra-smooth gameplay are the hallmarks of a true gaming monitor. With a 1ms rapid response time – the fastest available – the ROG SWIFT PG278Q Gaming Monitor eliminates smearing, tearing and motion blur, allowing you to quickly react to your game.
NVIDIA®G-SYNC™ display technology delivers the smoothest, fastest and most breathtaking gaming imaginable. G-SYNC™ synchronizes the ROG SWIFT's refresh rate to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. Scenes appear instantly, while objects look sharper and more vibrant. Gameplay is fluid and responsive too, ensuring a serious competitive edge.
The ASUS Display R&D team works closely with NVIDIA to ensure that everything runs smoothly on ASUS G-SYNC™ monitors. The ROG SWIFT PG278Q gaming monitor with built-in G-SYNC™ delivers super smooth and stunning visuals.
The ROG SWIFT PG278Q is compatible with the NVIDIA® 3D Vision™ 1 and 2 kits* to support up to three WQHD displays for immersive multi-display 3D gaming experience. ROG SWIFT provides the finest 3D gaming and content viewing experience and thanks to the ever-growing library of over 700 3D Vision™ ready game titles, as well as 3D Blu-ray movies and YouTube 3D Playback support. See everything in a new dimension with the ROG SWIFT.
*Requires NVIDIA® 3D Vision™ kit, sold separately.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by NVIDIA®G-SYNC™ technology
- Exclusive GamePlus onscreen timer/crosshair, 60-120-144Hz refresh rate turbo key and intuitive 5-way OSD navigation joystick
- Complete ergonomic tilt, swivel, pivot and height adjustment with VESA mount capability for optimal placement
Specification:-
- Fully adjustable stand: tilt/swivel/pivot/height
- Screen Size: 27" (68.47cm)
- Pixel Pitch: 0.233mm
- 2D mode: 2560x1440 (up to 144Hz)
- 3D mode: 2560x1440 (up to 120Hz)
- 2D Surround: 7680x1440 (up to 144Hz)
- 3D Surround: 7680x1440 (up to 120Hz)
- Panel: TN
- Colour: 16.7M (Real 8-Bit)
- Connectivity: 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- 3D Vision 2.0 Enabled
- G-Sync Enabled
- ULMB Enabled (NVIDIA Ultra Low Motion Blur Technology)
- Phys. Dimension with Stand(WxHxD): 619.77x362.96x237.9mm
- Box Dimension (WxHxD): 756x456x300mm
- Weight 7.5kg
- Full Specification: http://www.asus.com/Monitors/ROG_SWIFT_PG278Q/
- OcUK Exclusive Service: Warranty regarding dead pixels falls under ISO rules and as such dead pixels if very few are not an actual fault. But at OcUK we value our customers especially when spending such a large amount of money on what is a flagship gaming monitor. As such even if you only have 1 dead/stuck pixel and it has not gone after 3 days, we will class the monitor as faulty and exchange it for you at no cost to you. This service is exclusive at OcUK for Asus ROG Swift ONLY or other qualifying monitors! (Valid for 28 days from purchase)!
Was [£549.95] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
Asus VS278Q 27" 1920x1080 TN 1MS Gaming Widescreen LED Monitor - Black @ £169.99 inc VAT
Delicate touches make a monitor truly great, VS278Q Full HD LED monitor, with extremely quick 1ms response time, 80,000,000:1 high contrast ratio, DisplayPort and dual HDMI interfaces, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Your eyes are drawn to its unprecedented design—a fusion between the contrasts of gloss black and mat texture. Sleek texture with expressly designed vortex pattern on the pedestal and fingerprint-proof embossment at the back add versatility and the harmonious relationship of a line and circle to the monitor. The metallic stand delivers a sense of avant-garde and cosmopolitan chic. In itself, it is a work of art that accentuates any living space.
Specification:-
- Panel Size: Wide Screen 27.0"(68.6cm) 16:9
- True Resolution: 1920x1080
- Full HD 1080P: Yes
- Pixel Pitch: 0.311mm
- Brightness(Max): 300 cd/?
- ASUS Smart Contrast Ratio (ASCR): 80000000:1
- Viewing Angle (CR?10): 170°(H)/160°(V)
- Response Time: 1ms (Gray to Gray)
- Display Colors: 16.7M
- Stereo Speakers: 2W x 2 Stereo RMS
- Signal Input: HDMI x 2, D-Sub, DisplayPort
- PC Audio Input: 3.5mm Mini-Jack
- AV Audio Input: HDMI
- Earphone jack: 3.5mm Mini-Jack
- Tilt: +20°~-5°
- VESA Wall Mounting: 100x100mm
- Warranty: 3yr
Was [£179.99] Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
BenQ BL3200PT 32" 2560x1440 VA Widescreen LED Professional/Gaming Slim Bezel Flicker FREE Monitor - Black @ £329.99 inc VAT
Accurate Color Gamut that brings your imagination to life, A Large Screen that extends your design space, High Resolution to view the smallest details, Ergonomic Features that ease your eye and neck strain... Result, A monitor that meets all your CAD/CAM needs!
With a 2560x1440 WQHD resolution and extra working space mean less scrolls for zooming in and out. Start using BenQ CAD/CAM Monitor now and boost your work efficiency!
The unique CAD/CAM Mode is specially designed to enhance work efficiency and reducing eye fatigue for all CAD/CAM users. By making the color contrast higher, every displayed line will be perfectly distinguished. With BenQ CAD/ CAM Monitors, you will never miss a line again in your designed work.
To clearly distinguish detailed textures in the darkest areas, BenQ developed Animation Mode that enhances brightness in dark areas without overexposing bright areas. With ten levels of brightness, the Animation Mode provides the comfort and freedom that every designer will welcome with open arms.
With the BenQ’s advanced 100% sRGB screen technology, every color is delivered with the finest precision in every detail and at every possible viewing angle. Get and share a professional viewing experience.
Auto Pivot detects the rotation of the monitor and dynamically rotates displayed content automatically. All windows will be equally portioned and displayed on the screen when clicking on the Desktop Partition icon, which allows you to compare all design works with just, one simple click. Moreover, you can preset different picture modes to each frequently used software. Display Pilot will automatically switch to your preferred picture mode in different user scenarios.
Unique control device docked to the stand of every BL3200PT monitor remotely accesses the OSD menu. Three pre-set hot-keys allow quick switching between 1. sRGB Mode, 2. CAD/CAM Mode, 3. Low Blue Light Mode, or let you assign your own set of display modes providing ultimate user flexibility.
Large screen monitors usually take a noticeable amount of space on the working desk. BL 3200 is designed to save as much of your workspace as possible. Compact stand architecture enables the screen to sit at the very edge of the desk and maximize your working space and comfort.
I/O ports on the side of the screen effortlessly bring all your content together in one convenient package. 2x USB 3.0 and SD card reader provide super-speed data transmissions.
The slim bezel makes the monitor look lighter and larger. In a multi-display setup with two or more units, thin bezels are less intrusive and effectively expand your work-space.
An extensive range of monitor adjustments – height, tilt, pivot, stroke and swivel – tailor your own unique working station that is best suited for your height and viewing habits with a maximum 150mm distance between the screen bottom and the base.
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but they can certainly feel them. Free your eyes from flickers by switch to CAD/ CAM Monitors and let your eyes do less work while you are working on CAD/ CAM designs.
Every Monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset Low Blue Light Modes from OSD hot key (Multimedia – 30% reduction, Web-surfing – 50% reduction, Office – 60% reduction, Reading – 70% reduction), and reward your eyes without having to lose the visual enjoyment. Corporate users are frequently required to read documents from a monitor. Reading Mode adjusts the screen brightness, contrast ratio and sharpness to make your eyes feel as easy as reading directly from hard copies without wasting any paper.
Specification:-
- Screen Size: 32"W, VA LED
- Resolution (max.): 2560 x 1440
- Pixel Pitch: 0.276 mm
- Brightness: 300 cd/m2
- Contrast Ratio: 3000:1
- DCR: 20M:1
- Response Time: 4 ms GTG
- Display Color: 1.07 billion
- Viewing Angle (L/R;U/D) (CR>=10): 178 / 178
- Terminals: D-sub / DVI-D / HDMI / DisplayPort
- Flicker FREE technology
- VA (AMVA+) LED Technology
- Senseye® Human Vision Technology (plus Senseye 3)
- Advanced Motion Accelerator (AMA)
- HDCP Support
- Speaker: 5W x2
- USB Hub: Yes
- Dimensions(HxWxD mm) HIGH: 640.16*740.28*232.48mm
- VESA Wall Mounting (mm): 100 x 100 mm
- Warranty: 2yr (On-Site with BenQ - 0207 216 0039)
Was [£379.99] Inc. VAT
Only £329.99 inc VAT.
ORDER NOW
Philips BDM4065UC 40" 3840x2160 VA 4K 60Hz Widescreen LED Monitor - Black @ £529.99 inc VAT
See the big picture with all the details. The expansive 40" class Ultra HD professional Philips display gives you the room to spread out, see the big picture and all the details in Ultra HD. Expand your viewing experience with the monitor that is designed for the way you work.
These latest Philips screens deliver UltraClear, 4K UHD (3840x2160) pixel images. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like DisplayPort, HDMI, Dual link DVI, these new displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets. Philips displays will give you UltraClear images.
Philips VA LED display uses an advanced vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web-browsing, movies, gaming, and demanding graphical applications. It's optimized pixel management technology gives you 176/176 degree extra wide viewing angle, resulting in crisp images.
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturati on and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
Mobile High Definition Link (MHL) is a mobile audio/video interface fo r directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL capable mobile device to this large Philips MHL display, and watch your HD videos come to life with full digital sound. Now not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way.
Features:
- Expansive 40-inch class brilliant display
- UltraClear 4K UHD (3840x2160) resolution for precision
- VA display gives awesome images with wide viewing angle
- MultiView enables active dual connect and view at same time
- SmartImage presets for easy optimized image settings
- LED Technology ensures low power and natural colors
- Slim bezel design for a stylish look
- Powerful 7-Watt speakers to unleash your content
- USB 3.0 Hub for convenient access and fast charging
- SmartConnect with DisplayPort, HDMI and VGA connections
- MHL technology for enjoying mobile content on big screen
- VESA mount allows for the perfect setup
Specification:
- Display Screen Size: 40"
- Aspect ratio: 16:9
- Panel Type: VA
- Brightness: 300cd/m2
- Contrast Ratio: 5000:1 (Typ)
- Dynamic Contrast Ratio: 500,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 3ms (GTG)
- Viewing Angle (H / V ): 176 ° / 176 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz)
- USB 3.0 Hub: Yes
- Speakers: Yes (2x 7W Stereo)
- VESA: 200x200mm
- Warranty: 2yr (On-Site with Philips)
Was [£559.99] Inc. VAT
Only £529.99 inc VAT.
ORDER NOW
Samsung S32D850D 32" 2560x1440 VA Widescreen LED Professional/Gaming Slim Bezel Monitor - Black (LS32D85KTSN/EN) @ £389.99 inc VAT
Samsungs latest flagship monitor ideal for gamers, professionals and photography experts.
Specification:-
- Screen Size: 32"
- Panel Type: VA
- Backlight: LED
- Contrast Ratio: 10,000,000:1
- Pixel Pitch (HxV): 0.27675mmx0.27675mm
- Response Time: 4ms
- Viewing Angles: 178/178
- Colour Support: 1.07b
- Connectivity: Dual Link DVI, DisplayPort, HDMI, USB Hub
- Speakers: No
- Stand Type: Height Adjustable (130mm), Tilt, Swivel & Pivot
- VESA: 100x100
- Set Dimension with Stand (WxHxD): MAX:741.3×630×280, MIN:741.3×500×280mm
- Set Dimension without Stand (WxHxD): 741.3×441×68.5mm
- Review: http://www.trustedreviews.com/samsung-s32d850t-review-image-quality-uniformity-input-page-2
- Warranty: 3yr (On-Site with Samsung - 0330 726 7864)
Was [£499.99] Inc. VAT
Only £389.99 inc VAT.
ORDER NOW
Great deals are very nice monitors!! :)
Why must the Phillips monitor go on offer when I don't have the money :(
If I wasn't getting married in November this would be mine, wonder if the missus to be is ok with a card instead of a ring? :D
And if she knew, she will probably ask you if you think you will be ok with marrying a monitor instead of her :D
One thing for sure, the Philips will be no good in bed; as for in the kitchen...well that's debatable, as it would be for a different purpose lol
Was hoping for the Dell P2415Q to be on offer, though it has recently dropped in price, I've been hovering over the buy button for a while.
Yeah those ultra wide monitors are the bizz......i have two of the lg 29" ones , but at the moment I'm running two 27" 144Hz flicker free benq monitors and while I do like them...playing euro truck simulator and project cars is not the same or as nice as ultra wide
