- 25 May 2008
- North Wales
I've spent a good half hour looking up old cars on that, brilliant!
My old DC5 went on to have a good life..
Reason(s) for failure
front Windscreen wiper does not clear the windscreen effectively Both o/s and n/s (8.2.2)
Advisory notice item(s)
Long travel on handbrake
Both front (o/s n/s) brake hose ferrules have slight corrosion
Various body areas have slight corrosion
rear brake disc worn, pitted or scored, but not seriously weakened o/s and n/s (3.5.1i)
O/S/R brake binding
front Suspension arm rubber bush deteriorated but not resulting in excessive movement Both o/s and n/s (2.4.G.2)
Slight play in steering rack
Front coil springs corroded
nearside front Tyre worn close to the legal limit aprrox 2.7mm 215/45/17 87w (4.1.E.1)
offside front Tyre worn close to the legal limit aprrox 2.9mm 215/45/17 87w (4.1.E.1)
Catalytic convertor internals breaking up
Slight exhaust blow from rear section to middle section joint
Slight play on O/S/F shock absorber piston
Considering it's still a fairly sought after fairly expensive car (for what it is) it's been pretty neglected since i had it! Maybe i just dodged a bullet when i px'd it
O/S/R brake binding
