WIN THE POWERCOLOR DEVIL 13 390X2 16GB worth £689.99!
OcUK Staff
12 Apr 2008
OcUK HQ
We have gone absolutely nuts, we're working with KitGuru to give away the Powercolor Devil 13 Radeon R9 390X2 16GB graphics card worth £689.99!
Here is the card you can have a chance of winning!
Powercolor Devil 13 Radeon R9 390 X2 16384MB GDDR5 PCI-Express Graphics Card (AXR9 390 II 16GBD5) @ £599.99 inc VAT
PowerColor Devil 13 Dual Core R9 390 is built with carefully-designed Platinum Power Kit and ultra-efficient thermal design. It consists of massive 15-phase power delivery, PowerIRstage, Super Cap and Ferrite Core Choke that provides the stability and reliability for such high-end graphics solution. To support maximum performance and to qualify for the Devil 13 cooling system, 3 Double Blades Fans are attached on top of the enormous surface of aluminum fins heatsink connected with total of 10 pieces of heat pipes and 2 pieces of large die-cast panels. This superb cooling solution achieves a perfect balance between thermal solution and noise reduction. The PowerColor Devil 13 Dual Core R9 390 has the LED backlighting that glows a bright red color, pulsating slowly on the Devil 13 logo.
The Dual BIOS button design allows gamers to pursuit extreme performance in the easiest way to control. Four units of 8 pin PCI-E power connector draws more power offering constant and stable power input. What's more, to honor Devil 13 users, we have included the top-notch gaming mouse, the Razer Ouroboros, as a free gift inside the box. Why? Simply because we strongly believe our Devil 13 users deserves to have the best of the best.
The PowerColor Devil 13 Dual Core R9 390 graphics card supports for AMD LiquidVR™, GCN Architecture, Mantle, Exploit DirectX© 12, AMD CorssFire™, Virtual Super Resolution, HD3D technology, Frame Rate Target Control, and AMD FreeSync™ technologies. Once more, the Devil 13 has risen from Hell and will once again dominate the extreme gaming world with ease.
Specification:-
- GPU: Grenada Pro x2
- Stream Processors: 5120
- Core Speed: 1000MHz
- Memory Speed: 5400Mhz
- Memory interface: 512-Bit
- Memory capacity: 16384MB GDDR5
- PCI-Express X16 lane required
- 1000W Gold or greater PSU required
- Power Connectors: 4x 8-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Includes Razer Ouroboros Gaming Mouse
- Warranty: 2yr
Only £599.99 inc VAT.
ORDER NOW
HOW TO WIN!
To win you just have to show your interest to KitGuru that would like to review this graphics card, check out how to enter by clicking the link below!
http://www.kitguru.net/components/g...d-win-a-powercolor-devil-13-radeon-r9-390-x2/
Looks at the requirements, looks at computer ... :(
Not being a gamer I don't think I'll bother as it would be wasted on me ... good luck to those who decide to enter.
Yes, I'd be interested in giving one of these monsters a review, but no Failbook for me, so I can't.
