Man of Honour
- 5 Oct 2008
- Kent
Patheic. The only word to describe some of you.
I can think of plenty of other words to describe others on here.
There is a new registry setting which blocks O/S updates through Windows Update. Set this and then forget.
If you don't have Group Policy the fix is the registry setting I posted. Doesn't get much easier that a single registry setting.their a mucher easier way.
The official way for businesses from microsoft. (works on win7 pro)
open Group policy
under Computer Config > Admin Templates > Windows Components > Windows Update > Turn off upgrade Windows > Enable > Apply > Ok
if you do not have this in group policy you can download the patch publicly
Sure, having notifications is annoying when you don't want it, but I think it's a little bit dramatic to say they are forcing it.
Notifications =/= including it as a normal update so that it gets downloaded onto Win 7/8 machines that are set to auto-update.
It's not installed without giving the user the option.
I'm glad Microsoft are trying to publicize it all so well, and get people on board.
Surprised some people on here aren't still using Windows 95/XP with all the complaining going on.
The issue is not that it is installed (I know it is not, usually anyway), it is that it constantly nags the user even if they click "no." I personally would not complain if it came up with an icon, telling the end user to "Get Windows 10 now" and then had an easy way to opt-out and disable the icon, without having to be an advanced user, but it does not.
It would be really nice if people on here looked at things from other angles instead of through their eyes only.
I completely agree/understand. But coming along with a rage attitude is just likely to get the 'calm down it isn't that bad' response.
Then why download it to the machine in the first place then? It's just unnecessary.
I understand you don't want to be forced ion to an upgrade. That makes sense.
However Win 10 is a very good OS. So it's in your best interest to upgrade.
