Bitfenix Light Strip
Permabanned
2 Apr 2013
North West
I have just built a PC and added a Bitfenix light strip for use in the Phanteks Luxe. Nice case and the strip is extremely bright, but the stickyness of the strip is awful. Anyone else come across this? Will have to use something else to keep it stuck down, shocking that really considering the price of those things.:mad:
I have 2 of these, and can confirm the stickiness is indeed pants.. I thought they were releasing magnetic ones at some point.
I pushed mine down really hard they havnt fallen off again.. however I have some 3m vhb tape so I can always use that
I have also used the NZXT light strips which come with sticky pads, theyrnt very bright but ive got them round the inside of the case
I have the standard sticky version and its been fine. In fact, its slightly mis-aligned and won't budge. Its attached to the HDD vertical support wall
It happens.
I only peeled back the strip a little to work out if I had it in the right place.
Room temperature/whatever its sticking to temperature will have an effect too. My PC is in pretty constant use and the room maintains its temperature too.
The best solution that I used was to buy some 10mm sticky back magnetic strip. Got a 5m roll and stuck both sticky sides together, works a treat and easily removable.
Yeah we had to use some tape to hold the strip down properly in the end lads. Won't be considering buying them for myself or a customer again in the future unless the reviews improve.
