- 12 May 2012
Need help please - Win 10 system restart.
Whenever I select the Restart option from the Start menu the computer goes through its normal shut down procedure but instead of restarting when it should, it shuts down completely. The Shutdown option works correctly.
When I install a new program/drivers or windows updates it’s the same thing when trying to restart, the pc shuts down and I have to manually press the power button to get the pc to restart.
"not sure if this helps but this is on a completely new build pc - all new components & software"
