New build advice appreciated; please cast an eye over my build
3 Mar 2010
Staffordshire
Please cast an eye over my build any expert advice appreciated.
Is this ok or are there better alternatives available?
The system will be used for high resolution Photoshop work and needs to cope with several programmes open at one time such as Photoshop, Microsoft Office, Serif Web and so on. This isn’t for gaming.
Gigabyte X99-SLI - Intel Core i7 5820K Six Core CPU & Motherboard Bundle ***50 Saving*** @ £429.98
https://www.overclockers.co.uk/showproduct.php?prodid=BU-020-GI&groupid=701&catid=6&subcat=2858
Gigabyte GeForce GTX 960 OC 4096MB GDDR5 PCI-Express Graphics Card (GV-N960OC-4GD) @ £158.99
https://www.overclockers.co.uk/showproduct.php?prodid=GX-171-GI&groupid=701&catid=1914
Kingston Predator 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit – Black (HX430C15PB2K4/16) @ £139.99
https://www.overclockers.co.uk/showproduct.php?prodid=MY-202-KS&groupid=701&catid=8&subcat=2557
Akasa BayMaster Card & Drive Reader (AK-ICR-10) @ £11.99
https://www.overclockers.co.uk/showproduct.php?prodid=FL-005-AK
Keeping Existing:
Crucial CT128 SSD as a boot drive for operating system
M4 CT256 SSD as programme drive & Seagate 1Tb SSHD as storage drive
CD/DVD RW x 2
Dell U2311H monitor
XFX XXX 650W PSU
Can you recommend:
A decent CPU Cooler (£30-£70)?
A suitable case which will take 2 x DVD/RW and 1 x USB 3.0 3.5” Memory card reader (£30-£70)?
Thank You :)
That looks ok.
Consider using low profile RAM such as Corsair LPX or Kingston Fury as then you can fit an air cooler easier.
Here is a case+cooler recommendation,
My basket at Overclockers UK:
Total: £127.24
(includes shipping: £12.30)
Edit, urrgh no 3.5" bay.
https://www.overclockers.co.uk/be-q...ee-pure-rock-cpu-cooler-bundle-bu-001-bq.html
Free cooler with this case, as long as your fan controller doesnt stick out as this case has a door.
That looks ok.
Thanks Stulid, something like this then? Would it be worth going to 4x8Gb?
Kingston Fury Black 16GB (4x4GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Black (HX424C15FBK4/16
https://www.overclockers.co.uk/king...nnel-kit-black-hx424c15fbk4-16-my-213-ks.html
Do you rate this cooler or am I spending extra without the need?
Hydro H60 V2 High Performance Liquid CPU Cooler (CW-9060007-WW)
https://www.overclockers.co.uk/cors...iquid-cpu-cooler-cw-9060007-ww-hs-006-cs.html
Excellent RAM that Fury stuff, do you need 32GB? that is the question, also certain Window versions have memory limits.
https://msdn.microsoft.com/en-gb/library/windows/desktop/aa366778(v=vs.85).aspx
I dont rate that cooler and you would find a £30-40 air cooler quieter and performing better at a lower noise DB.
If you want an AIO at least go for a 240mm/280mm (if the case supports it) radiator type.
Brilliant thanks Stulid. Your right I won't need 32Gb and I will take your cooler advice, thank you.
I have finalised my spec now and hopefully it will all be compatible and the PSU powerful enough. Is this all ok or should I make any adjustments? Thanks.
Antec GX500 Midi-Tower – Black @ £39.95
https://www.overclockers.co.uk/antec-gx500-midi-tower-black-ca-219-an.html
https://www.overclockers.co.uk/showproduct.php?prodid=bu-020-gi
gigabyte geforce gtx 960 oc 4096mb gddr5 pci-express graphics card (gv-n960oc-4gd) @ £158.99
https://www.overclockers.co.uk/showproduct.php?prodid=gx-171-gi
kingston fury black 16gb (4x4gb) ddr4 pc4-19200c15 2400mhz quad channel kit - black (hx424c15fbk4/16 @ £99.95
Alpenföhn Matterhorn White CPU Cooler Stock Code HS-051-AL @ £39.95
https://www.overclockers.co.uk/alpenfoehn-matterhorn-white-cpu-cooler-hs-051-al.html
IcyBox 3.5" USB 3.0 Multi Card Reader with USB Charging Port (IB-868-B) @ £19.94
https://www.overclockers.co.uk/icyb...ith-usb-charging-port-ib-868-b-hd-104-bt.html
£788.76 in total
Keeping Existing:
M4 CT256 SSD as program drive & Seagate 1Tb SSHD as storage drive
CD/DVD RW x 2
XFX XXX 650W PSU
Dell U2311H monitor
