- 11 Mar 2013
Point is OP wants the best CPU for gaming not matter the cost, that will be the i7 6700k then.
This 100% ^
I don't need any GPU I have 3 Titan X at my disposal. Why I want to build my own I have upgraded all my old pc just part by part but I want to move up from 1150 low end to a better cpu and motherboard. The whole part of the debate of the 5930k is the extra 40 lanes over the 16 of skylakes for gaming. As I would buy the Asus x99-we to take advantage of the lanes to run at 16 each.
Proformance over price at this moment in time.
i7 6700k 4.0ghz or i7 5930k 3.5ghz.
Yeah budget is around £1000 left for it. With the cards I bought two and got one as gift, pretty much a £3500-£4000 build as I got lucky with some gambling and decided to upgrade my pc.
As for parts I already have is ddr4 ram, 1200w psu, gpu and my water cooling components. Really just the mobo and cpu I need as I'm taking my Samsung 1tb ssd out my old computer.
And thanks again guys for info and help.
Wrong, clear advantage to skylake over haswell in a number of games in the tests below, large increase in some games. So yeah higher IPC over them extra two cores you will never likely use whilst gaming.
^ Yo mate, what voltage is your 5820k stable at 4.5? Just curious.
This 100% ^
If you truly want 'the best CPU for gaming not (sic) matter the cost' you would still want to go X99 currently as tri SLI Titan X's would running (multiple) high res monitors be better served by the increased native PCI-E lane count and the increased core count of X99 over Z170 despite the small average per core MHz drop overclocked from X99 to Z170 unless your idea or 'best' includes running games at 1080p on your new uber rig!.......
Its irrelevant anyway
You can't tri sli on z170.
1.3v
1.3265 volts iirc, on laptop now!
edit
just checked and its set slightly lower...
under water cooling when torture tested hits about 70c in a hot room due to wife having heating on all the time(26 - 27C)
Seems a bit toastier than I've seen.
What batch #s?
