**** The Official Google Nexus 6P Thread ****
How odd then!
I guess if it was a camera update, then it may well reset display parameters too.
My order is still pending done :/
Can anyone recommend a decent set of mobile headphones that won't cost the earth? Forgot Nexi don't come with them :(
Xiaomi Piston 3's are very well regarded if you want something with a built in mic/controls. I've just ordered some. I understand Penton audio have a very good reputation as a store. Be careful if you find them cheaper elsewhere there are a lot of fakes floating around.
Thanks, I'll have a look. Tbh I'm not too fussed on a mic - its mostly going to be for music and films rather than calls
So off the phone with Google and I'm pretty sure the order still stands, was told to wait afew hours and my google account will start processing orders...
Reviews good apart from outdoor visibility which is pretty important in a mobile device in my opinion.
That's half and half too. Some reviews say outdoors is fine. If it's anything like the Note 3 panel (we know it's better) then it will be fine, as I had no issues with the Note 3 screen outdoors in sunlight at max brightness (adaptive off, it gets brighter with this turned off like most screens).
Just got shipping notice and tracking number from Google for my 32GB Graphite...... Delivery is via Parcelforce. Tracking number not live yet though.
