A decent set of 225/45's is gonna set you back 3-350
Whys he selling them so cheap? Or are they second hand?
They were bought for someone, but their mind changed and he is stuck with them. hence the low price.
[TW]Fox;28736714 said:Don't you just hate it when you randomly buy somebody a full set of wheels and they change their mind and leave you stuck with them? Happens all the time.
Wait, what? Seems fishy.
Seen some horrendous pics of a GTR with adapters on and the wheels hanging off after a spirited drive. Look like the adapters simply split![]()
Yeah, wobble nuts (bit sketchy) or adapter spacers. Much better just buying the right spec wheels.
I've used wobble nuts before to fit a 4x100 wheel in a 4x98 car, didn't have a single problem.
5x112 to 114.3 definitely works with wobble nuts.Would you say that the 5x112 would fit my car then? (if Center bore is a match)
Tbf spirited driving in a GTR is a different kettle of fish. Typically they will be absolutely fine. I know plenty of people that drift/race with spacers on and its not really an issue. You're more likely to tear apart a cheap alloy.
