Gsync as the AOC ultra wide is too many pixels for my 980 to push well for gaming.
His build uses a 980ti,
http://forums.overclockers.co.uk/showpost.php?p=28726591&postcount=660
I need a monitor and ideally would be ultrawide gsync but with Xmas coming up and a second child due December I can't afford dropping a grand on one so it has to be one or the other at the moment for half that![]()
So after all this time i've either fixed G-sync or just got it working better than before.
If i turn off my second monitor (BenQ) it makes most of my games run amazin in Gsync, not so much on controller but on mouse its superb.
No idea what happened lol.
Guys, how can i set fps limit while using g-sync monitor? For example in games like cs go and menus I will get out of g-sync range, but enabling v-sync is not an option anyway. Nvidia inspector is old and not working with latest drivers.
So today I've had the opportunity to try Gsync for the first time as I have a Acer Predator monitor here for a friends new build.
It is as good as people say it is.
That is all.
I currently have a 1440p 60Hz IPS panel and have been tempted numerous times to give G-Sync a try but I refuse to pay the crazy prices for a 1440p IPS G-Sync device.
Would you deem it worthwhile to have a secondary monitor, say 1080p TN G-Sync for FPS games exclusively?
its good but is not worth the price they ask for it
its pure rip off
Yes, that is how I do it, The big AOC on the left for movies and whatever as it's a superior IPS, then a smaller 24" 144Hz on the right for games,
Prior to the big AOC I had a 27" ASUS 1440P PLS panel next to the 24" 144Hz and used it in exactly the same way.
PEBCAK![]()
How much should it cost?
Aha i embraced the fact i'm probably 95% of the problem behind my pc![]()
And so the pc build is done and it and the monitor have been collected so back to normal 144Hz I go
Highly recommended and was a pleasure to experience during these past couple of days playing games.
whilst gsync seems nice, it is shady from nvidia to use propriety tech which happens to double the price of a monitor when freesync tech is available. So personally i have found the cost too hard to justify especially as gsync monitors have very limited inputs as well.
I'm playing GTA V and being able to drop from 95 to 80fps and not notice a thing is great.
