Have Motherboard etc sockets changed?
27 Feb 2004
Kent
Going about a rebuild and want to re-use components.
I have a Corsair modular 600W power supply CX600M bought in 2013 (as new) - this has modular leads for HDDs etc. but fixed leads for mb etc. - will these still be compatible with a new motherboard - thinking of a Asus Z97M-Plus or Asus Z79-K
Thanks, Mel :)
The Corsair CX isn't the best power supply in the world. They are better suited to Office/Low end systems, but to answer your question yes it will be compatible.
Thanks - it is used / to be used in a general purpose (browsing / email / word / excel) / photo-editing / 2nd PC - definitely not for gaming!
So prob OK!!
I can still use my 9 or so year old Akasa PSU with a modern motherboard since the power connections are the same.
Just checking again
Motherboard - 24 way power socket; 8 way cpu power socket
PSU - 18 or 20 way power plug (can't see properly); 4 way cpu power plug
SO - I just use one half of the cpu power plug; and leave sockets 11,12,23,24 without anything plugged in?
Is that right? Thanks, Mel
Just checking again
What CPU are you using in the board? A low power one should work fine, but something more powerful such as an i7 for example (maybe even an i5) might struggle.
This (using on-board graphics so no separate card);
CP-540-IN Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail
MB-605-AS Asus Z97-K Intel Z97 (Socket 1150) DDR3 ATX Motherboard.
Not a gaming machine - just photoshop etc.
Just checking again
You can try it with just the 4 pin cable that is hardwired into the psu. If it doesn't boot for some reason, then just use the modular 8 pin EPS cable.
The larger 24 pin cable obviously plugs into the 24 pin socket on the board.
You won't need the pci-e cable if you are using integrated graphics.
Just checking again
Just googled your PSU and the result i found said you should have
1 x 24 pin cable
1 x 8 pin 12v EPS cable
Both should be hard wired, (unless this is a newer version).
Maybe not the best PSU nowadays, but should be fine.
