Don
- 20 Oct 2002
- Oxfordshire / Bucks
I use a specialized Romin expert 143mm version as the bike fitter suggested I get that, I got one, and its amazing
Nothing wrong with thatI came across this T-Shirt the other day - very tempted to order
Any recommendations for a cheap waterproof rucksack? Like £50 or so? I came across the Alpkit Gourdon dry sack which is just £25 which looks like an absolute bargain.
See I think that's the sort of geometry I want to try out (thinking some 'individual side flex' might help on longer rides to stop some chaffing - the main reason I'd ended up looking at Fizik was their 'wings' tech) but I'm also conscious of every-day 'commuting comfort', which is why I also thing a relaxed/scooped middle might be the way forwards. I'm not ideally after a 'race' saddle for performance gains...
The look of it is important as well - one of the reasons I'd semi decided on Fizik. Because y'know all the pro's use them so we should be too (you know I like my loud colours/decals)
I guess as we've previously discussed - a saddle is a very personal thing and I'm better to try them out rather than reading this and that online (as per usual I'm over-researching the whole thing!)![]()
I want something waterproof enough that I'm confident putting a grand worth of work laptop in there![]()
are you looking for a bike specific ruc sac ? or a general one?
all the reviews I've read (I bought the saddle long before reading any reviews) are all true
the bike came with the Toupe one, and it was good, but this romin with the cut out makes it a lot lot better, so glad I bought one
Ah, I would suggest looking more towards a laptop specific one rather than just a waterproof rucksack...! Mine only carries clothing & food!
May see if my LBS have one I can borrow, they fitted me with Specialized Body Geometry so I'd be very surprised if not. But then I'm almost resigning myself to buying it from them at retail...![]()
That depends on whether including the word "cycling" anywhere near it doubles the price as it does with most other things!
Lowe Alpine make very good bags
http://lowealpine.com/uk/shop/mens/everyday
you can get a waterproof cover from them from rainforest etc
if you do buy one, make sure its the 2016 model or the cheaper 2015 model
don't get a second hand one or a past year ones as there is a fault with them (as I took mine back)
It calculates from the speed sensor, as it has no way to read resistance from the trainer - my garmin could read 18mph but on screen it'll be doing 5mph as it's up a hill...
Zwift doesn't use resistance, it calculates the power from speed/cadence sensors to calculate against your HR (and I believe age & weight) to come up with a 'virtual' power (zpower) which determines your progression on screen. The progression through the course/track determines the resistance and measures your power output against it to determine your progression.
My jacket is killing me, I may as well wear a 5p shopping bag, the 2 little air holes would give me more ventilation!
Recommendations for a new Jacket for Autumn/Winter/Spring? Abitrary budget is £100, though I'd stretch to more if it's totes worth it.
Requirements:
1) Waterproof (or very water resistant)
2) breathable. no more boil-in-the-bag!
3) good visibility. I love the look of the proviz 360, but I tried one on and the fit is awful. Reflective bits and not black will do!
4) Warm but not too warm![]()
What do we think of patterned bar tape? I'm thinking of getting some black and blue for my pompino.
