The best thing is for you to run a few games and see how they do on your new monitor. If you delay your card upgrade longer there is more chance your next one will be a 14NM/16NM which will be more powerful and have better DX12 support.
Lol ok...
looking at the specs the 980 is more of a side grade or is this my upgrade route?
If I can pick one up in MM for 250 ?
It's getting stuttery when really busy in the pre sequel...
Hope for a good deal on the 980ti on black friday sales?
Personally don't rate the 980 as a significant upgrade over the 780 though it would help in VRAM limited situations and 1-2 games where Maxwell seems to be a big advantage.
As a general overview what clocks should I be looking at on the 780 ?
When are these new cards due mate ?
Need to compare apples to apples.![]()
Depends on which core revision a bit - the older ones will often struggle over 11xx without BIOS mods, etc. but the OC models with the revision B cores should do 12xx easily, 13xx with BIOS mods for voltage/k-boost, etc. beyond that you'd need uprated cooling (or a very good clocker).
Check what boost clock you are actually running in game with GPU-z.
What's the ASIC quality. Check what ram it uses, epileda sucks for clocking.
I've never seen real gains from VRAM overclocking on mine outside of specific benchmarks like Heaven.
What does the sensors tab in GPU-z show after running a game for a bit?
