- 30 Nov 2011
hi im a little confused with this whole gsync thing
i have turned vsync off in my nvcp.
and i have set my monitor at 100hz it works fine (gcard is a 980TI)
gsync is showing up in my nvcp ok but when i run games my led lights are blue?
now a lot of users are saying when gsync is actually working the led lights go red?
can anyone confirm this
as i honestly cant tell if gsync works or not and ive not had gysnc before
but i used to just run my old panel at 120hz and with vsync off,
if i run games like csgo or tf2, my fps are high like 280 and i have been told
gsync does not work unless you are under 100fps.
but is there an actual way to know your gsync is actually on and doing something?
as i just cant physically tell a diference between this panel and my old panel
when running games?
thanks.
turn Vsync OFF in game, then run either an FPS limiter, OR Turn ON Vsync in NVCP
the reason you are getting 280fps is because you are running no vsync and no frame limiter
