- 12 Sep 2012
- Surrey
I know it'll sound like a broken record but the 290x really does run ridiculously hot and loud. Are you sure you don't want to go nvidia?
How hot did your 290x get?
Both my reference ones never went above 85 before they had blocks put on them and the after-market cooler ones are far better.
The Tri-X is an excellent card. The cooler is hefty and the PCB is reference so you have the option of watercooling or replacing the cooler if you want to (although there is no need with the tri-x)
Ignore that KoM guy, he is just trolling every thread with the same post. From the looks of things, he either has no idea on GPUs or is just provoking reactions. What happened to the three strikes rule Mods?
How much are you getting paid?
