Recommened on the skoda/VW forums
and for peace of mind. I don't need to explain myself.
[TW]Fox;28741552 said:The reason this has happened is because you've asked for an incredibly unusual job that very few people ever get done and as a result the dealer, unfamiliar with ever doing it, has screwed it up.
I've had a similar problem. Had my clutch done and when I drove off the gear box oil was leaking. So I took t back and he put some generic stuff in and now it's stiff putting it into second in the morning. They blamed the gear box
I would agree though that any garage that claimed a clutch fault based on your description should not be used again.
Stiff gear changes are very commonly caused by clutch problems.
[TW]Fox;28743361 said:A manual gearbox oil change is not part of the service schedule of many cars at all. It is not a standard service task.
Mercedes and VW are fairly unique in having scheduled oil changes for automatics, many manufacturers don't mandate those either.
So you're saying that because the book doesn't say so, there's obviously no need for it?
I've changed gearbox oil in all my cars to know that it's been done and is upto spec. I don't think there's any problem changing oil at 60k, why the heck not? Also, it's not an incredibly hard job for anyone to do actually, so a garage, this should be bread and butter and quite frankly if I garage wasn't sure how to do this on a car, I'd walk away!
Recommened on the skoda/VW forums and for peace of mind. I don't need to explain myself.
Thats alright the foums know best over Skoda![]()
trained Skoda enthusiasts
