Get lost. What I meant was it is a forum aimed at motor enthusiasts and often have trained mechanics on there that know what they're talking about. I'd much more be inclined to listen to those, than car dealers themselves.
So much hostility in motors today lol
So you mean the people trained the same as the people you took the car to!?
They're trained, they just failed to see the necessity to use the correct oil.
Can you prove it? Stranger coincidences have happened.
Anyway just drop the oil and replace it yourself with whatever you like, job done. People are now just on the wind up and you're biting![]()
I can't, and that's the plan. I'm not biting any more. I've RTM the thread, and requested its closure. Sick of the attitude in this place.
I'm done.
Ahahahahahahahaha. Let's listen to Barry on the internet![]()
TBH, the RX8 forum I go to 100% knows more than any Mazda dealer currently I know of... so, in certain circumstances, I would take the knowledge (within reason) off a forum as opposed to a dealer. Remember, I've just took JEEP to court for fitting a gearbox to a JEEP (Brand new) and it's took them THREE yes 3 Gear Boxes to get it right!!! That's a dealer... and they caused orther problems while it was there. Bear in mind, their poor fitment of the original cooler caused my heartache in the first place!
So, in the replies that go on about reading off forums as opposed to dealers, yes in certain circumstances you should just incase! Use every available knowledge source!!! but rely on NONE 100%
Also, is that not what every single person in here does? get advice of other enthusiasts? if you don't want that, I'm failing to see why people would post anyway surely? Do we not post questions to get opinions, i.e. LIKE THE ORIGINAL OP DID?
haven't even owned a TSI engine...
Perhaps, but my clutch is fine. It went in fine, came out with new transmission oil, and all of a sudden, changes are notchy and stiff.
The oil viscosity appears to be the same and the active parts of direct shift gearbox are fundamentally the same a a manual box i.e. it's a constant mesh design that uses the same type of synchromesh system to synchronise gear speeds. The only major difference is that the older DSG boxes have wet clutches which may require some specific oil formulations to work correctly.
