- 22 Mar 2007
I've currently got the Acoustic Energy Aego M 2.1 system connected to my PC at home, but I'm noticing some reverb and sound distortion, particularly with certain bass-heavy music genres and at higher volumes. This might just be a limitation of the system or they might be on their way out, but either way it means that I'm thinking about a new set of speakers.
I'm thinking about going for a decent 2.0 system and forgoing the sub, mainly because it seems like there is much more choice when it comes to 2.0 setups. I've been looking at both active and passive speakers - presumably the only difference is that I would need a DAC for passive speakers?
In terms of options, I'm currently liking the look of the Q Acoustics 3010 or 3020, are there any other speakers that would be a better option? I had a look at a few of the Wharfedale speakers but they all look pretty massive.
