Online MOT History
Odd, I've not been able to access it for the last week.
"You can’t check the MOT history of a vehicle. The service is currently unavailable."
Seems fine now :)
Funny searching for old cars and seeing MOT advisory of 'heavily modified' when it came to my Skyline, LOL
Not sure if I should be worried :eek:
MOT history of this vehicle
Test date19 August 2015 Expiry date18 August 2016 Test Result Pass Odometer reading 73,032 miles MOT test number9553 0123 5265
Test date18 August 2015 Test Result Fail Odometer reading 73,032 miles MOT test number5580 7063 5270 Reason(s) for failure
Nearside Rear Lower Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Nearside Rear Lower Suspension component mounting prescribed area is inadequately repaired (2.4.A.3)
Offside Rear Lower Suspension component mounting prescribed area is inadequately repaired (2.4.A.3)
Offside Rear Brake load sensing valve seized (3.6.E.3)
Test date12 August 2015 Test Result Fail Odometer reading 73,028 miles MOT test number3549 0917 6288 Reason(s) for failure
nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
offside Windscreen wiper does not clear the windscreen effectively (8.2.2)
nearside outer Suspension component mounting prescribed area is excessively corroded sill (2.4.A.3)
offside rear inner Suspension component mounting prescribed area is excessively corroded sill (2.4.A.3)
nearside rear inner Suspension component mounting prescribed area is excessively corroded sill (2.4.A.3)
rear Brake load sensing valve seized (3.6.E.3)
offside rear coil spring broken (2.4.C.1a)
nearside front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Test date23 April 2014 Expiry date22 April 2015 Test ResultPass Odometer reading72,606 miles MOT test number8659 0381 4163
Test date15 April 2014 Test Result Fail Odometer reading72,594 miles MOT test number3995 6570 4134 Reason(s) for failure
Nearside Front position lamp(s) not working (1.1.A.3b)
Nearside Headlamp insecure (1.7.3)
Nearside Headlamp aim too low (1.8)
Offside Headlamp aim too high (1.8)
Offside Front coil spring broken (2.4.C.1a)
Offside Rear Tyre has ply or cords exposed (4.1.D.1b)
Advisory notice item(s)
Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Offside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
nearside rear tyre splitting
Probably corroded due to sitting around, it's only done <500 miles since the last MOT, has it done similar mileage in previous years? Must be surface rust as I think any holes or anything near such mountings would be a failure. Unless the inadequate repair is quiksteel/paper mache.
The 2007 Focus ST I sold last year has still only ever had a single advisory for worn front disks. At 70k miles I expected more considering how it got thrown around on country roads :)
What could be the reason that it can't find my old Jag?
Just says cannot find any records for that vehicle. Works for every other car I've tried except that
No idea but it does exactly the same for a friends car.
Only thing I can think of is cars that have previously had a private plate
Must be missing some parts of the database, my nissan doesn't show up on there but everything else does including ones that were scrapped years ago.
Not bad for a petrol Vauxhall.....:D:cool:
Might sell before mileage starts to put people off.
this is great when looking for a used car as you can rule so many out without bothering to go and look at them. e.g called one guy up, any issues on the last couple of MOTs "no mate its golden", look it up, advisory last three years for oil leaks lol
