there are 3 AIO coolers for gpus that i know of.
kraken g10 - ugliest by far.
corsair hg980 - very nice and should fit your gpu.
evga hybrid - very nice but not sure if its fits anything other than evga.
i think they all need an actual h55 or h60 or h80 to be purchased separately though.
What resolution though 1080?83c is nuts!!
My MSI 6G only just hits 68c with some of the more demanding games!
Firstly why did you buy a case named after a band member in West Life?
Secondly 83c is nothing to worry about with these cards, it's probably slightly higher than normal but then that could be down to your West Life case's airflow or fan profile.
Thirdly you can hybrid your card as other people have suggested. Someone has done the Amp Extreme
http://forums.overclockers.co.uk/showpost.php?p=28354858&postcount=5343
and I am sure that on OCN that people have done it to the regular amp edition just double check you have a heatsink of the VRM modules incase you need to buy some but you should be okay I think.
edit - you're fine
https://www.techpowerup.com/reviews/Zotac/GeForce_GTX_980_Ti_Amp_Edition/4.html
who are westlife?
planning on getting this case for my green x99 build
https://www.overclockers.co.uk/cors...-cube-case-black-cc-9011030-ww-ca-143-cs.html
83C is fine. A lot of GPUs won't throttle until they hit over 100C.
not true with the 980ti, I noticed it throttled around 67c. Can't remember the exact temp but it was around there.
Leading on from this post, check this youtube video out at around 2 minutes in, he's modified his 540 side panel with what appears to be a 200mm fan, GPU temp 65°C overclocked to 1500MHz with the MSI 980 Ti Gaming Edition.Wow, I didn't realise how bad that Bitfenix Ronin case is for cooling, check the GPU Delta results >> http://www.bit-tech.net/hardware/cases/2013/08/09/bitfenix-ronin-review/3
I didn't think the Corsair Carbide Air 540 was that great, as I had one myself, the results above in the link say it's good 7°C better for GPU cooling. I've seen a few people modifying their side panel when using SLI with this case though.
What gpu's are these out of interest?
Even the hottest running gpu i know the 290 series which had a 94/95 target temp which wouldn't throttle till it hit these temps was the highest ive seen.
Over 100 now WOW![]()
I think Nvidia had some 500 series cards that got just as hot as Hawaii though.
But it could lead to annoyingly loud fans.83C is fine. A lot of GPUs won't throttle until they hit over 100C.
No way ahould it throttle at 67c its in the 80's it throttles.
Most of the 980ti's dont even start their fans till 60c
my boost clock speeds did at 67c I just checked some old posts I made.
