OcUK Staff
- 26 Nov 2014
- Stoke
It's payday and I've got some pretty epic deals to offer you on Cases, PSU's and Gaming Chairs, have a goosey at the below highlighted TWO offers!
XFX 1050W Black Edition Pro 80 Plus Gold Modular Power Supply - Black @ £109.99 inc VAT - CHEAPEST IN THE UK
XFX's unique, continuous EasyRail technology enables you to maximize available power and make setup easy. Stack numerous power-hungry components, such as your GPU, CPU and other components, without fear of crashing. It's also a perfect solution for hardcore gamers. Multi-rail PSUs are safe and often preferred, but it's just not equipped to handle the power-hungry components of today's gaming systems--especially if it's a multi-GPU or multi-CPU setup. Multi-Rail PSUs breakdown power bands into smaller, individual rails so it's possible for over-current and system shutdowns to occur. What's needed is one, big, reliable rail for all of your components. For real high-power gaming needs, XFX EasyRail is the only choice.
SolidLink technology allows XFX PSUs to drastically reduce the wires inside. Other PSUs have numerous wired internal components, which generate heat, wasting energy and decreasing efficiency. SolidLink Technology replaces traditional wired connections with direct pin to port connections. This reduces heat generated by wires which in turn reduces lost wattage giving you clean, consistent high quality voltage.
Traditional Full Modular PSUs tend to have a bundle of cables which generate heat causing wattage loss. This means the PSU has to actually pull in more wattage to make up for the loss to give you the wattage your computer needs. SolidLink Full Modular PSUs don't have all these primary wires, instead using pin lag that directly connect to the connector daughter board which drastically reduces the lost wattage--meaning you'll draw less wall power which saves you money
Features
- 80Plus Gold Certified
- Crossfire and SLI Ready
- Haswell Ready
- EasyRail Plus Technology
- Hybrid Fan Control Modes
- Compatible with Intel Core i3, i5, i7 and AMD Phenom, FX
- DC to DC Converter Design
- Conductive Polymer Aluminum Solid Electrolytic Capacitors
- Active Power Factor Correction [99% PF Typical]
- High +12V Output
- Ultra Ventilation [Grid Structure]
- Multi-GPU Technologies Supported
- All-in-One DC Cabling Design
- Universal AC Input [Full Range]
- 5 Year Limited Warranty
Specifications
- +12V Rail Outputs : Multi-rail
- ATX12V 2.2 & ESP12V 2.91 Compliant : Yes
- Maximum Wattage (W) : 1050W
- Modular Cables : Yes
- Performance Category : Black
- AC Input Current (Arms) : 13-6.5 (Maximum)
- AC Input Frequency (Hz) : 47-63
- AC Input Voltage (Vac) : 90-264
- Active Power Factor Correction (PFC) : Yes
- DC to DC Converters (+3.3 & +5V) : Yes
- EZ Grip Connectors : Yes
- High Reliable 105°C Japanese Capacitors : Yes
- Solid State Capacitors : Yes
- Tight voltage regulation (±5%) : Yes
- OCP/OPP/OTP/OVP/SCP/UVP Protections: Yes
- Cooling Fan Size (mm) : 135
- Intake Fan: Airflow (CFM/min) : 94.8
- Intake Fan: Diameter (mm) : 135 x 135 x 25 mm
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 8-Pin EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 6 x 6+2-Pin-PCIe
- 11 x SATA
- 8 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
Was £134.99 Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
Silverstone SST-FTZ01B Fortress Mini-ITX- Black (SST-FTZ01B) @ £99.95 inc VAT
In early 2014, a revolutionary slim form factor case called the RVZ01 was created by SilverStone's RAVEN team that exceeded and redefined what a slim HTPC or console-styled PC case could do. As a follow up, SilverStone created another new line called the Fortress Z to cater to enthusiasts with affinity for all metal design in slim form factor cases, thus the FTZ01 was born.
Similar to RVZ01, the FTZ01 utilizes a PCI-E riser and custom designed fans to accommodate the biggest consumer graphics card on the market with superb air cooling performance and the ability to support liquid cooling*. Designed for use in either vertical or horizontal orientation, it can be placed comfortably in any space-constrained environment that requires a powerful PC. For those looking to build a premium, all-metal slim form factor PC, there is no better choice than the FTZ01.
Features
- Classic exterior built from aluminum unibody frame
- Supports graphics card up to 13 inches
- Mini-ITX motherboard & SFX PSU compatible
- Maximum performance in slim form factor with support for liquid cooling*
- Positive air pressure design for excellent cooling/quietness and dust-prevention
- Fits in nearly any environment with horizontal or vertical orientation
Specifications
- Model No: SST-FTZ01B (black)
- Material: Aluminum unibody frame, steel chassis
- Motherboard: Mini-DTX, Mini-ITX
- Drive Bay: External - Slim slot-loading optical x 1, Internal - 3.5" x 1, 2.5" x 3
- Cooling System: Front - N/A, Rear - N/A, Side - N/A, Top - 1 x 120mm fan, 1500rpm 18dBA, Bottom - 1 x 120mm fan, 1500rpm 18dBA, 1 x 120mm fan slot
- Expansion Slot: 2
- Front I/O Port: USB 3.0 x 2, Audio x 1, MIC x 1
- Power Supply: SFX, SFX-L
- Expansion Card: Support graphics card up to 13”, width restriction – 5.88”
- Limitation of CPU cooler: 83mm
- Net Weight: 4.6kg
- Dimension: 376mm (W) x 107mm (H) x 351mm (D), 14 liters
- Extra: Support Kensington locks
Was £112.95 Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
BitFenix Prodigy Mini-ITX Cube Case - Aqua Blue @ £44.99 inc VAT
Meticulously crafted and beautifully engineered, Prodigy redefines the Mini-ITX chassis. The compact housing is suspended by handles made with BitFenix FyberFlex™ Composite for easy portability and maximum shock absorption. The spacious internals give you the flexibility to install up to five 3.5" hard disks or no less than nine SSDs. The modular FlexCage™ can also be removed entirely to fit long graphics cards and water cooling radiators up to 240mm in length, and a choice of Midnight Black or Arctic White with available interchangeable face plates mean Prodigy will suit your individual style. With tool-free convenience, two USB 3.0 ports, filtered intakes, and proprietary BitFenix SofTouch™ Surface Treatment, Prodigy is the compact case with no compromises.
Specifications
- Beautifully Compact – Mini ITX dimensions with clean modern styling
- Unmatched Flexibility – Supports long graphics cards and up to 240mm water cooling radiators
- BitFenix FyberFlex™ Composite Handles – For portability and shock absorption
- Maximum Storage Potential – Install up to five 3.5" or nine 2.5" SSDs
- BitFenix FlexCage™ - Modular hard disk cage can be completely removed for added flexibility
- Choose Your Own Style – Two color options and interchangeable face plates available
- SuperSpeed USB 3.0 – Two ports included for blazing file transfers
- BitFenix SofTouch™ Surface Treatment – Luxurious matte finish and soft feel
- Trouble-free Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
- Dimensions (WxHxD): 250 x 404 x 359mm
- Motherboard Sizes: Mini-ITX
- 5.25” Drive Bays: x 1 (removable)
- 3.5” Drive Bays: x 5 (3 + 2 modular)
- 2.5” Drive Bays: x 9 (5 + 2 + 1 +1 )
- Cooling Front: 120mm x 2 (120mm x 1included) or 140/180/200/230mm x 1(optional)
- Cooling Rear: 120mm x 1 (included) or 140mm x 1(optional)
- Cooling Top: 120mm x 2 (optional)
- PCI Slots: x 2
- I/O: USB 3.0 x 2, HD Audio
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: FyberFlex™ Composite handles, SofTouch™ surface treatment, filtered intakes, tool-free drive locking
Was £59.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Cougar CMD 600W Digital '80 Plus Bronze' Modular Power Supply @ £49.99 inc VAT
With COUGAR’s new generation of power supply units, the PSU is not anymore a cold metal box. The COUGAR CMD series allows the user to interact with and configure his PSU, and use it to monitor, protect and gain extra knowledge about other components from his PC. Gamers will be able to monitor and control a broad number of variables. The COUGAR CMD series bring you an unprecedented level of monitoring, optimization and customization.
Features
- EXTREME INTERACTION: Adjust all voltage levels and keep them stable under different operating conditions:Fine tune your power supply!
- EXTREME ILLUSTRATION: Full Graphical and Numerical display of power consumption current status and historical database for easy analysis.
- EXTREME INTEGRATION: Monitoring of all aspects of the system; complete information about your PC.
- EXTREMELY HIGH EFFICIENCY: 80-PLUS® Bronze certified: Provides up to 88% of efficiency. Less Cost, Less Heat, Less Problems.
- LIFELONG OPERATION LOG: Helps you to review all the operating conditions in a specific operating period, including Power Efficiency, Voltage, Fan Speed and many more.
- 2 CASE FANS WITH ADJUSTABLE SPEED: This PSU supports (not included) up to two case fans connected to it and allows the user to adjust their speed through the COUGAR UIX software.
- INSTANT SCREENSHOT FUNCTION: Conveniently and Quickly capture the on-screen information with a single click, allowing you to keep record of any specific graph that is relevant to you.
- ELECTRIC CONSUMPTION COST ESTIMATION: This function allows you to estimate your computer’s energy consumption and, according to the data you provide, estimate its cost.
- ADVANCED MODULAR CABLE MANAGEMENT: Simplifies Cable Management, thus improving ventilation, reducing air friction and maximizing airflow.
- ULTRA-QUIET & TEMPERATURE-CONTROLLED 140MM: Extremely low noise level, with fan speed automatically governed according to the PSU temperature.
- 105°C JAPANESE CAPACITORS: Best reliability and 4 times the lifespan of conventional 85ºC rated capacitors.
- DC - DC TECHNOLOGY: DC.- DC technology provides the highest efficiency level, most stable performance, and most accurate regulation, always within +/- 3% of the selected voltage.
- SINGLE 12V RAIL FOR STABLE OVERCLOCKING PERFORMANCE: With the Holistic Protection Mechanism, the single 12V rail arrangement will allow for high and stable overclocking performance.
- FLAT & MODULAR CABLES: A simpler cable management which allows you to minimize the number of cables, using only those which are needed. This improves ventilation, reduces air friction and maximizes airflow, as well as making installation simpler and neater.
- FULL PROTECTIONS WITH OCP, SCP, OVP, UVP, OPP
Cougar UIX Software
The COUGAR UIX System keeps lifelong records of power data in easily understandable graphs for the user to review and share. Efficiency levels; output and consumption and rail voltage and current data are all easily accessible. All Voltage levels can not only be monitored but also adjusted, allowing for tight voltage regulation.
Visualize the temperature and usage of each PC component and control Fan speed to minimize fan sound while you keep the temperature under control.
Connectors
- 2 x 6+2-Pin-PCIe
- 6 x SATA
- 3 x 4-Pin-Molex
- Warranty: 3 Years
Was £66.95 Inc. VAT
Only £49.99 inc VAT.
order now
Cougar CMD 500W Digital '80 Plus Bronze' Modular Power Supply @ £44.99 inc VAT
Features
Cougar UIX Software
Connectors
- 2 x 6+2-Pin-PCIe
- 5 x SATA
- 3 x 4-Pin-Molex
- Warranty: 3 Years
Was £59.99 Inc. VAT
ORDER NOW
Seasonic S12II 350W '80 Plus Bronze' Power Supply @ £29.99 inc VAT
The S12II Bronze Series achieves the 80 PLUS® Bronze standard of at least 82%, 85% & 82% power usage efficiency at 20%, 50% & 100% operating loads respectively. This, combined with Active Power Factor Correction, enables the S12II Bronze to reduce energy waste, boost power efficiency and more importantly, reduce the energy costs for the users.
In addition to the efficiency upgrade, the S12II Bronze Series maintains the strong foundations of the S12II series. Important features such as the stable and proven Double Forward Converter circuit design, the industry leading Smart and Silent Fan Control (S2FC) and the use of high reliability Japanese brand capacitors are all carried forward to the “Bronze”.
The S12II Bronze Series, similar to its predecessors, is available in the standard ATX Form Factor and in wattages that are most common for a PC system. In addition to the all-in-one cabling design, the 520W and 620W models come with additional EPS connectors for IPC and server systems and supports both 6P & 8P PCI-E connectors for the most current and high end dual graphic cards.
Features
- 80PLUS® Bronze Certified High Efficiency
- Highly Reliable 105 degree Japanese Brand Capacitor
- Ample +12V Outputs
- Double Forward Converter Design
- Smart & Silent Fan Control [S2FC]
- 12cm Ball Bearing Cooling Fan
- Soft-Mount Rubber Cushions
- Universal Video Card Support
- Patented Easy Swap Connector
- Ultra Ventilation [Honeycomb Structure]
- 5 Year Warranty
Specifications
- 80PLUS®: Bronze
- Form Factor: Intel ATX 12 V
- Dimensions: 150 mm (W) x 140 mm v(L) x 86 mm (H)
- Fan Size: 120 mm
- Fan Control: Seasonic S2FC
- Fan Bearing: Fluid Dynamic Bearing
- Life Expectancy: 50,000 at 40 °C, 15 % - 65 % R.H.
- Modularity: Fully Wired
- Cable type: Flat black cables
- Operating Temperature: 40 °C
- MTBF @ 25 °C, excl. fan: 150,000 hours
- AC Input: Full Range
- Protection: OPP, OVP, UVP, SCP
- Safety and EMC: cTUVus, TUV, Gost-R, UkrTEST, CB , BSMI, Semko, CCC, CE, FCC, C-tick
- Environmental Compliance: Energy Star, RoHS, WEEE, REACH
- Warranty: 5 Years
Was £39.95 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
AK Racing Nitro Gaming Chair - Orange @ £169.99 inc VAT
All AK Racing seats come with multiple points of adjustability so that you can tailor the position of the seat perfectly.
Features
- Colour: Orange & Black
- Quality upholstery material. NITRO series uses PU Leather.
- Metal Construction: Each seat has a sturdy metal frame.
- High quality, comfortable hard foam, not prone to deformation over time.
- Adjustable Armrests.
- Adjustable Back Angle: 180-degree backrest adjustment allows you to adjust it to your needs.
- Adjustable tilt, height and back.
- Reinforced wheels: designed not to scratch hardwood or laminate floors.
- Very Strong Metal base with class 4 gas lift support up to 150KG.
- Cushions Included for optional lower back and head/neck support.
Dimensions
- Shoulder Width: 540mm
- Waist Width: 500mm
- Seat Width: 370mm
- Back Height: 920mm
- Seat Length: 560mm
- Seat Height: 500-420mm
- Armrest Heights: 340-270mm
Was £199.99 Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
AK Racing Premium Plus V2 Gaming Chair - Red @ £209.99 inc VAT
PREMIUM PLUS SERIES
AK Racing seats offer stylish esports looks alongside well considered ergonomics.
Boring office chairs are the last thing any gaming enthusiast wants! Don't suffer these boring solutions any longer, now you can have the same style chair that professional gamers use in tournaments around the world!
Perfect for office workers and gamers, AK Racing seats are a high quality and exciting solution to the various health disorders resulting from bad posture.
Styled after Race Car seats and implementing very high quality materials, AK Racing are the ultimate desk accessory and compliment your pro gamer attitude perfectly whilst being hard wearing and durable. Featuring supportive seat bolsters, just like a real bucket seat, your posture will be perfect whilst at your desk.
- Height adjustment - Set your desired height by using the lever underneath the chair.
- Backrest adjustment - Perfect for when you want to lay back and take a break from whatever you are doing!
- Rocking function - The chair can be tilted up to 12-degrees, it also lockable in the upright position to prevent the chair from rocking.
- High-quality materials - PU Leather that is both great-looking and easy to clean.
- Class-4 gas lift - Durable for up to 150kg!
- Durable wheels - Cool looking wheels that make it very easy to move the chair around.
- Metal frame - A durable metal frame structure ensures durability for years to come
Dimensions
- Shoulder Width: 580mm
- Waist Width: 530mm
- Seat Width: 375mm
- Back Height: 940mm
- Seat Height: 510-430mm
Was £239.99 Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
Here's a few forum exclusive deals on popular lines that will be available till midday on Monday!
Phanteks Enthoo Evolv ATX Mid Tower Case - Black @ £124.99 inc VAT
Addressing the online community’s desire for the ATX verison of the Enthoo EVOLV case, Phanteks have released the new Enthoo EVOLV ATX to the EVOLV series. A premium mid tower chassis with an aluminum exterior with minimalistic design based on the original Enthoo EVOLV. The EVOLV ATX features the quick release side panel system, innovative top radiator bracket, and the new HDD mounting system.
Like the EVOLV, the EVOLV ATX retains the full 3mm thick aluminum outer panels with the quick release system. The EVOLV ATX features a 4 color changeable power LED. With the EVOLV series ranging from mini ITX to micro ATX, the EVOLV ATX features a large interior to support full ATX systems. Unleash unlimited possibilities with the Enthoo EVOLV ATX.
Features
- Aluminum body (3mm thick)
- Clean interior - Hidden PSU and HDD’s
- Power LED - Changeable to 4 different colors
- Retractable Radiator Bracket - Convenient Installation
- Toolless Sidepanel with swing door
- Side Window to show off your componenets
- Quick release panels for easy access
- Equipped with 3 x Phanteks PH-F140SP 140mm Fans, PWM Hub, 35mm Cable Management Space and Phanteks Velcro Ties
- Bottom and Front Dust Filters
- 2 x SSD Brackets Included
- 3 x Modular 3.5" HDD Bracket included
- Watercooling ready with Reservoir/Pump Mounts and space for up to 360mm radiators on Top/Front Panel
Specifications
- Dimension: 235 mm x 495 mm x 510 mm (W x H x D) 9.25 in x 19.5 in x 20.1 in
- Form Factor: Midtower
- Colour: Satin Black
- Material(s): Aluminum (3mm), Steel chassis
- Motherboard support: E-ATX *(up to 264mm wide), ATX, Micro ATX, Mini ITX
- Front I/O: 2x USB 3.0, Mic, Headphone, Reset
- Side window: Yes
- Expansion slots: 7
- Internal 3.5”: 8x (5x included)
- Internal (dedicated) 2.5”: 3x (2x included)
- Air Cooling Support: Front - 3 x 120mm, 2 x 140mm (2 included) , Top - 3 x 120mm, 2 x 140mm, Rear - 1 x 120mm, 1 x 140mm (1 included)
- Liquid Cooling Support: Front 120mm - Up to 360mm, Top 120mm - Up to 360mm, Rear 120mm - 120mm, Front 140mm - Up to 280mm, Top 140mm - Up to 280mm, Rear 140mm - 140mm
- PH-F140SP Included Fan Spec: Speed (rpm) - 1200 ± 250 rpm,, Max Airflow: 82.1 CFM, Static Pressure - 1.33mm H2O, Acoustical Noise - 19dB
- Graphic card clearance: 420 mm (16.54 in) No HDD brackets, 300 mm (11.8 in) HDD brackets installed
- CPU cooler clearance: 194 mm (7.6 in)
- Cable management: 35 mm (1.38 in)
- Memory clearance (motherboard - fan): 120mm: 68 mm (2.68 in) , 140mm: 48 mm (1.89 in)
- Model: PH-ES515E
- Net Weight: 10.2 kg (22.0 lbs)
- Gross Weight: 11.9 kg (24.3 lbs)
- Package Dimension: 310 mm x 570 mm x 564 mm (WxHxD)
- Warranty: 5 Years
Was £139.99 Inc. VAT
Only £124.99 inc VAT.
ORDER NOW
NZXT H440 New 2015 Edition Case - Matte Black - No Window @ £79.99 inc VAT
Taking feedback from the community, NZXT has applied highly requested feature updates to its acclaimed H440 case with a renewed emphasis on cooling performance and function.
The new H Series Chassis from NZXT features a doorless, ODD-free front panel made entirely of steel while a large, full-view window reveals an interior specially engineered to make any build seamless and beautiful. This case puts a firm emphasis on the ethos of clean computer builds. Every design characteristic has been considered to assist even novice system builders in creating showcase level systems.
On the inside, an integrated power supply shroud completely conceals cables and increases cable management space up to 80%. Additionally, two attached SSD trays mounted above the shroud allow you to easily showcase a remarkably clean interior.
The H440 comes standard with 360mm of direct CPU/GPU cooling behind its front panel, offering an unprecedented level of cooling right out of the box. Supporting both 140mm and 120mm fans, the steel top and front panels come ready for up to 360mm water cooling radiators to offer comprehensive water cooling performance in a sleek, minimalist package.
With its newly designed interior, the H440 guarantees a streamlined PC-building experience without sacrificing any features that builders demand in a high performance chassis.
Features:
- Increased height and depth with re-designed ventilation for better airflow
- PWM fan hub
- 8 x SSD storage
- HDD trays re-designed to support top and bottom mounted drives
- Tinted black window
- Newly upgraded scratch resistant paint
Technical Details
- Model Number: CA-H442C-M8
- Colour: Matte Black - No Window
- Drive Bays: External 5.25": 0, Internal 3.5"/2.5": 10+1/8 (Total 7 Combined)
- Cooling System: Front: 2x 140/3x120mm (3 x 120mm FN V2 Fans Included), Top: 2x 140/3x120mm, Rear: 1x 140/120mm (1 x 140mm FN V2 Fan Included)
- Filters: Front (Included), Bottom Rear(Included)
- Radiator Support: Front 2 x 140 or 3 x 120mm, Top 2 x 140 or 3 x 120mm, Rear 1 x 140/120mm
- Clearance: GPU Clearance With HDD Cage: 294mm, GPU Clearance Without HDD Cage: 428mm, CPU Cooler: 180mm
- Cable Management: Lowest Point - 17.7mm; Highest Point 32.5mm
- Dimensions: 220mm x 512mm x 480mm
- Material: Steel, Plastic, Metal plated front panel
- Motherboard Support: Mini-ITX, MicroATX, ATX
- Expansion Slots: 7
- External Electronics: USB3.0 x 2, USB2.0 x 2, 1 x Audio/Mic, I/O Panel LED On/Off
- Product Weight: 10.16 kg
- Warranty: 2 Years
Was £99.95 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
be quiet! Silent Base 600 Midi Tower Case - Black Window @ £79.99 inc VAT
be quiet! Silent Base 600 Window offers the perfect symbiosis of noise prevention and cooling performance, a good usability and an extensive capacity for high-end hardware. The design team’s mission was based on the principle “form follows function”, and so every last detail in the Silent Base 600’s design has a functional purpose. It is truly a superior case ideal for high-end gaming gear and quiet systems.
Features
- Outstanding performance thanks to an innovative construction that assures excellent cooling efficiency and a perfect air-circulation at well-known whisper-quiet operation.
- Excellent usability with simplest mounting and tool-free fitting of drives, an intelligent and adaptable cable solution, and air intake filters that are easily accessed for cleaning.
- Ample space and cutouts are provided for high-end components of today and tomorrow, including space for water cooling radiators.
- Two pre-installed Pure Wings 2 fans feature nine airflow-optimized fan blades and are decoupled from the case to circulate air with a minimum of vibration and the quietest possible operation; 3-step fan controller included.
- Side panel with double-glazed window provides a perfect view inside the PC system; the window is made from scratch and impact resisting material and offers a superb soundproofing.
- Professional cable management is supported with generous space for organizing cables, silicone rubber grommets, and carefully placed pass-throughs.
- Product conception, design and quality control in Germany.
- 3-years manufacturer’s warranty.
Specification
- Form factor / Motherboard compatibility: ATX / ATX, Micro-ATX, Mini-ITX
- Case size (L x W x H in mm): 495 x 230 x 493
- Colour: Black
- Material: 0.7mm steel, ABS plastic, Nylon
- Weight incl. package / without package (kg): 9.7 / 8
- I/O Panel: 2x USB 3.0, 2x USB 2.0, HD Audio (mic + headphone jacks)
- Expansion slots (pcs.): 7
- Drive Bay Capacity: 5.25" - 3, 3.5" - 3, 2.5" - 3
- Cooling System: Pre-installed fans (mm / rpm) - 1x 140 / 900 @ front, 1x 120 / 1,200 @ rear
- Optional fans (mm) : 2x 140/120 @ top, 1x 140/120 @ bottom, 1x 140 @ front
- Optional liquid cooling system (radiator in mm) : 1x 120/140 @ front , 1x 120 @ rear, 1x 240/280 slim type(top)
- Cooling solutions : Air channels (top and front) - 3-step fan controller
- Maximum Dimension: CPU cooler (mm) 167, PSU (without bottom fan) 290, Graphics card (standard) 290, Graphics card (w/o middle HDD cage) 400
- Insulation and Damping: Front panel / Side panel insulation mats, Anti-vibration decoupled HDD / fan / PSU
Was £94.99 Inc. VAT
ORDER NOW
SuperFlower Leadex Platinum 650W Fully Modular "80 Plus Platinum" Power Supply - Black @ £84.95 inc VAT
Superflower, one of the worlds leading power supply manufacturers have unleashed a full Leadex Platinum range, all with 80 Plus Platinum Certification, offering up to 92% efficiency with class leading features, as well as offering capacities from 550W - 2000W.
All Leadex Platinum Power Supplies feature a fully modular design, 135mm silent DBB PWM Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The Leadex Platinum series are a brilliant choice for anyone who wants great performance and efficiency in their system, along with the flexibility of various wattages to suit everyones needs.
Features
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Platinum Certified, 90% 92% 89% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection / Over Temperature Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specifications
- Dimensions: 150 x 86 x 165 mm (W x H x D)
- Wattage: 650W
- Fan: 135 mm DBB(automatic control, semi-passive)
- Colour: Black (power supply, fan)
- Fully Modular Design
- Efficiency: max. 92% (115V), 80 Plus Platinum certificate
- Active PFC
- Safety: cTUVus/TUV/CB/CE/FCC/C-Tick/BSMI/RoHS/CCC
- Partcode: SF-650F14MP black (UK)
Connectors
- 4 x 6+2-Pin-PCIe
- 8 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
Was £98.99 Inc. VAT
Only £84.95 inc VAT.
ORDER NOW
Antec EDGE 650w 80 Plus Gold Fully Modular Power Supply @ £79.99 inc VAT
Description
Antec's EDGE series is the pinnacle of power supplies. EDGE is fully modular with a revolutionary 18+10-pin MBU socket for the needs of tomorrow. By using a PSU that is 80 PLUS® GOLD & ErP Lot 6: 2013 certified, operating up to 92% efficient, you can reduce your electricity bill by up to 20% when compared to many other power supplies.
EDGE's innovative 16-pin sockets create a new level of flexibility by doubling the modular connectivity, supporting two different 8-pins connectors and even future connectors of 10, 12, 14 or 16-pins. All cables are darkened and also flat (except MBU cable) to become Flat Stealth Wires and are thus nearly invisible in your chassis. 2 High Current Rails and a ~99% +12V output ratio maximize EDGE's capabilities to power the latest CPU's & GPU's.
CircuitShield™ makes EDGE safe and reliable in any environment with its 7 industrial-grade protections. Backed by a 5 year warranty and lifetime global 24/7 support, EDGE embodies everything a power supply can accomplish today.
Specifications
- 650W Continuous Power - Guaranteed 650W of Continuous Power from Antec
- 80 PLUS® GOLD certified - Up to 92% efficient, to reduce your electricity bill
- AQ5 - Antec Quality 5 year warranty and lifetime global 24/7 support
- 16-pin Socket - Industry-leading 16-pin sockets double the modular connectivity by supporting 2 different 8-pin cables per socket and allow for future connector changes
- 135 mm LED FDB Silence - Whisper-quiet high-quality LED fluid-dynamic bearing fan with long lifetime
- Thermal Manager - An advanced low voltage fan control for optimal heat & noise management
- High Current Rails - 2 +12V rails with high load capabilities ensure maximum CPU & GPU compatibility
- 98.2% +12V - Output for maximum CPU & GPU support
- 28(18+10)- pin MBU socket - For possible future MBU connectors
- CircuitShield™ - Full suite of industrial grade protections: Over Current Protection (OCP), Over Voltage Protection (OVP), No Load Operation (NLO), Short Circuit Protection (SCP), Over Power Protection (OPP), Over Temperature Protection (OTP) & Surge & Inrush Protection (SIP)
- Japanese Heavy- Duty Caps - High-performance Japanese capacitors ensure tightest DC stability and regulation
- Flat Stealth Wires - Flat and darkened wires for minimal visibility in chassis (except MBU cable)
- ATX12V 2.4 - Engineered according to the newest PSU guideline and compatible with the latest CPU generation
Connectors
- 1 x 20+4 Pin
- 1 x 8 Pin EPS
- 4 x 6+2 PCI-E
- 9 x SATA
- 6 x MOLEX
- 1 x Floppy
- 5 Year warranty
Was £89.99 Inc. VAT
ORDER NOW
Vertagear Racing Series S-Line SL2000 Gaming Chair Black/Red Edition @ £159.95 inc VAT
A combination of form and function, Vertagear’s SL-2000 series focus on ergonomics, design, and functionality. Designed to give wide range of adjustability that gives gamers the best comfort and support in every gaming position for extended period of time. High backrest is designed to provide neck, shoulder and lumbar support.
Adjustable seat height
To prevent repetitive stress, having the correct ergonomic posture is important when seated for a longer time. Seat adjustability makes sure every type of user from different heights can adjust the chair to their unstressed posture. Good range of height adjustability to ensure you are at the optimum angle in relation to your desk.
Adjustable armrest
Cushioned and contoured to the shape of the arm with adjustability in height gives support to the gaming arm and prevents repetitive stress.
Adjustable back
Features independent back angle option. An angle-adjustable backrest to help you adjust your sitting position throughout the course of your gaming experience (up to 170 degrees).
Elegant Exterior
The SL2000 is made of high quality PVC leather, which makes it extremely durable and gives the chair a luxurious look. This material is easy to clean and maintain due to it’s stain- and water-resistant characteristics.
Comfort Padding
The SL2000 padding is made of high densed foam, which adds great support and seat comfort to the chair. The open-cell breathing structure, makes sure that heat arised from the human body temperature won’t get trapped inside. This gives great comfort to the user even when seated for extended period of time.
Solid Structure
The SL2000 is constructed from a steel frame that assures a solid structure. The aluminum alloy 5-star base keeps the chair solid, stable and lightweight. Assembled with a Class 4 gaslift, iindicates for better durability and ease of use. Our Class 4 Gas Lift has thicker walls to accommodate the higher pressure and stability.
Tilting feature with adjustable resistance and locking system
Our adjustable tilt tension mechanism allows you to increase or decrease the tension by easily turn the knob to match your body weight. This allows you to rock comfortably, without heavy pushing, reducing muscle fatigue.
Extra accessories
Additional neck support cushion and lumbar support cushion is included.
Soft-glide Wheels
Wheel is formulated for a quieter operation and greater resistance to foreign objects and debris.
Specifications
- Overall height (incl. base): 1280 - 1360 mm
- Width backrest (shoulder): 555 mm
- Width backrest (lumbar): 290 mm
- Width seat: 370 mm
- Depth seat: 540 mm
- Material(s): Steel (frame), High density resilient foam, PVC leather, Aluminum alloy (feet)
- Max. Load: 150 kg
- Colour: Red
- Model: VG-SL2000
- Net Weight: 20 kg
- Gross Weight: 24 kg
- Package dimension: 880 x 400 x 680 mm
- Warranty: 2 years
Was £184.99 Inc. VAT
Only £159.95 inc VAT.
ORDER NOW
AK Racing Gaming Chair Black Red @ £154.99 inc VAT
Features
- Colour: Red & Black
- Quality upholstery material. GAMING series uses fabric.
- Metal base with class 4 gas lift support up to 150KG.
Dimensions
- Seat Width: 370mm
Was £179.99 Inc. VAT
Only £154.99 inc VAT.
ORDER NOW
I'm feeling generous so maybe I can be persuaded to do a few one off deals on other Cases, PSU's and Gaming Chairs too
Let me know in here if there's anything in particular!
Features
- Haswell Ready
- High +12V Output
Specifications
Connectors
- 1 x 8-Pin EPS12V
- 6 x 6+2-Pin-PCIe
- 11 x SATA
- 8 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
ORDER NOW
Features
Specifications
- Expansion Slot: 2
- Net Weight: 4.6kg
ORDER NOW
Specifications
- PCI Slots: x 2
Was £59.99 Inc. VAT
ORDER NOW
Features
Cougar UIX Software
Connectors
- 2 x 6+2-Pin-PCIe
- 6 x SATA
- 3 x 4-Pin-Molex
- Warranty: 3 Years
Was £66.95 Inc. VAT
order now
Features
Cougar UIX Software
Connectors
- 2 x 6+2-Pin-PCIe
- 5 x SATA
- 3 x 4-Pin-Molex
- Warranty: 3 Years
Was £59.99 Inc. VAT
ORDER NOW
Features
- 5 Year Warranty
Specifications
- 80PLUS®: Bronze
- Fan Size: 120 mm
- Warranty: 5 Years
Was £39.95 Inc. VAT
ORDER NOW
Features
Dimensions
- Seat Width: 370mm
ORDER NOW
PREMIUM PLUS SERIES
Dimensions
- Seat Width: 375mm
ORDER NOW
Features
Specifications
- Side window: Yes
- Model: PH-ES515E
- Warranty: 5 Years
ORDER NOW
Features:
- PWM fan hub
- 8 x SSD storage
Technical Details
- Warranty: 2 Years
Was £99.95 Inc. VAT
ORDER NOW
Features
Specification
- Colour: Black
Was £94.99 Inc. VAT
ORDER NOW
Features
Specifications
- Wattage: 650W
- Active PFC
Connectors
- 4 x 6+2-Pin-PCIe
- 8 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
Was £98.99 Inc. VAT
ORDER NOW
Description
Specifications
Connectors
- 1 x 20+4 Pin
- 1 x 8 Pin EPS
- 4 x 6+2 PCI-E
- 9 x SATA
- 6 x MOLEX
- 1 x Floppy
- 5 Year warranty
Was £89.99 Inc. VAT
ORDER NOW
Adjustable armrest
Adjustable back
Elegant Exterior
Comfort Padding
Solid Structure
Extra accessories
Soft-glide Wheels
Specifications
- Max. Load: 150 kg
- Colour: Red
- Model: VG-SL2000
- Net Weight: 20 kg
- Warranty: 2 years
ORDER NOW
Features
Dimensions
- Seat Width: 370mm
ORDER NOW
