TBH just drain the fuel out, fill it up with the correct stuff and try it. I bet it still works fine. The faults are most likely just contaminated sensors. Putting the wrong fuel in doesnt do THAT much damage.
But why then would the garage sign off on contaminated fuel and agree to provide a sample?
That's what I thought, but the garage are saying it's the fuel thats caused it and it does seem a hell of a coincidence that an injector and fuel pump are throwing up faults just after I fill up. I even confirmed the fault codes before I called the AA as I have a fault reader so I know the garage aren't lying about these.
I get the feeling Nasher didn't read the thread lol
One thing I picked up on is you said Premium Diesel. Not the cheaper diesel that 99% of other people will use? That maybe why no one else had the issue. And I suspect the premium stuff had been sat around for so long it no longer classed as diesel, let alone premium.
Maybe try the local news paper and see if they run a story. Even if its online only where people can leave comments.
Petrol in a fuel injected diesel is a nightmare especially if it has been started and driven.
Tesco only sell one grade of diesel
A separate but equally perplexing problem is the natural degradation of diesel fuel. A diesel engine uses only some of the fuel it pulls from the tank. All of that fuel goes through the high-pressure fuel pump and to the injectors operating under enormous pressure and high temperatures. The surplus fuel the engine is not using goes back to the tank. This fuel is continuously re-circulated and exposed to extreme pressure and heat, which results in the agglomeration of asphaltenes, the high carbon content, heavy end fuel molecules. It leads to the formation of larger and larger clusters and solids, which are very difficult to completely combust. These solids may grow so large that they will not pass through the filter element. They become part of the polymer and sludge build up plugging the filter.
In addition, the hot fuel coming back to the tank will raise the fuel temperature in the tank, cause condensation (water accumulation in the bottom of the tank) and contribute to microbial contamination, fuel break down, bio fouling and the build up of sludge and acid.
Large fuel droplets and high asphaltene concentrations require more time, more energy and higher temperatures to combust than is available in engines during the combustion cycle and before the exhaust valve opens. Any device in the fuel system exposing the fuel to stress (heat and pressure) such as pumps, heaters, or centrifuges will increase the formation of asphaltenes. If you have seen fuel that has turned dark, or almost black, in comparison to clear, bright fuel, then you have witnessed the results of this process. This degraded, dark fuel negatively impacts combustion.
That site actually backs up the theory that it wasn't petrol in the pump. For a start the black is from it sitting for more than a day, yours didn't.
It also says that you'd get much further than a few minutes away with the fuel that's in the pipes. Finally, it also says, like a lot of people here have said, that petrol would rarely cause that much damage.
I'm pretty convinced you've suffered common garden diesel fuel system failure.
If I was in your shoes I'd be weighing up whether I'd want to pay to fix the car, assume it's coming out your pocket and there's nobody else with liability. If it comes to light later that the petrol station was at fault you can seek to reclaim costs - but you stand to be significantly out of pocket if your ahead with the repair on the assumption that someone else will foot the bill
By far the biggest question mark for me, simply doesn't make sense. If it was a problem with the station then others would have been affected. The OP may not be aware of them but Tesco would be and I can't see them trying to trot out the denials ad nauseum if their doors were being beaten down with multiple complaints.
He said he put premium in. Does that mean the station brand being premium or like V power diesel. Few others put premium diesel in I imagine?
