What fps you getting maximum and minimum
Cheers
I'm guessing this is a poo port ?
Runs perfect at 1920x1200 on my 780, can't tell if it dips fps or not tbh but runs very nice.
It will be the vram which is killing the frames. Try turning down the view distance to help with frames. 780 @ 1080p needed the view distance to be about half way to keep the vram usage to below 3gb.
I ran at full view distance and vram usage was around 2.9GB on my rig (780Ti).
Only thing I reduced to help keep it at 60FPS was foliage at high rather than very high.
