Moved house, new router required!
14 Nov 2012
Chesterfield
I've iust moved into my own place (first time) and I have access to my landlords wifi, until by ADSL is installed, but the signal is shocking!
I'm after a router that supports:
- ADSL
- FTTC
- VPN
- Wireless Bridging
Are there any suggestions that don't break the bank? Sub £100
If you can stretch a tad, go for the TP Link Archer VR900 - fantastic router. Had it a few weeks now and it's awesome! :)
One of if not the only (maybe the Netgear D7000 as well?), bug-free router I say that just works. As opposed to the ASUS' which are just too buggy, generate errors and have various issues.
Not used it so can't comment, but you know that's a router only right? Thought your OP suggests you're after a modem as well, or do you just mean one that 'works' in conjunction with a standalone modem?
Just found the spec page on the manufacturers website, would appear it does! Will keep this one and see what other suggestions arise!
