- 20 Dec 2010
- Lincolnshire
Not as underwear, base layers - so on top on a pair of boxers, but otherwise next to the skin.
And yeah you can wear them for a few days and they won't start to smell of stale sweat/BO.
See that's the one thing I don't think will work. I wear pretty loose boxers and these skin tight base layers don't look compatible. I googled it most seem to consider base layers to be thermal underwear, which makes sense to me, otherwise I also have to invest in tighter underwear.
Yeah as I stupidly chose not to go for the Aldi deal, merino wool is looking a bit too expensive. I'll see how I fare with the cheap synthetics and if they don't do the job I'll invest in the expensive stuff, which will cost a fortune if I don't want to have just one set.
