Hi there
This has got to be the best looking memory yet, if you like Black/Red themes and love a bit of Asus ROG which I do, very Elite Tier hardware.
Avexir Impact ROG Series 8GB (2x4GB) DDR4 PC4-21300C15 2666MHz Dual Channel Kit - Red Light @ £74.99 inc VAT
VEXIR Impact series is designed for overclockers, gamers and enthusiasts. By AVEXIR AIST IC sorting technology, each module has 100% overclocking guarantee and hand test for higher overclocking challenge.
Compatible with low-profile CPU coolers
Being low height, Impact series has no clearance issues with CPU coolers. , Impact series gives you a fitting design at remarkable performance. Unleash the gamers' spirit within with AVEXIR LED patent lighting tube, Impact series is not only a powerful DDR4 memory solution, but also enabling you to animate your PC to the rhythm of breathing.
ROG Certified series memory modules are using highest grade of original IC only such as Samsung, Hynix, and Mircon. In addition, Avexir promises to produce ROG certified memory modules only with ROG VIII series motherboards. Built for your confidence, ROG certified memory modules passed 16 hand-picked AIST (Avexir Ic Sorting Technology) processes and 14 memory module functional, burn in, and compatibility tests. AVEXIR built top level specification of Impact series by using 10 layers performance optimized design printed circuit board and industrial grade resistors and capacitors.
ROG certified memory performance enhancement can be done via genius Ai Overclock Tuner feature, you are just one click away to enables special overclocking function to unleash the power within.
Features:
- Exclusive patented technology of LED tubes
- 10 layers performance optimized design printed circuit board
- Exquisite packaging
- Support XMP 2.0
- Hand picked AIST(AVEXIR IC Sorting Technology)
- ROG Partnership branding
Specification:
- Black PCB
- Black ROG high performance heatspreaders
- Red LED Strobe effect (See product images)
- CAS Timings: 15-15-15-35
- Dual Channel Kit: (2x4GB)
- Lifetime Warranty
Only £74.99 inc VAT.
ORDER NOW
Avexir Impact ROG Series 16GB (2x8GB) DDR4 PC4-21300C15 2666MHz Dual Channel Kit - Red Light @ £149.99 inc VAT
Features:
- Support XMP 2.0
Specification:
- Black PCB
- Dual Channel Kit: (2x8GB)
- Lifetime Warranty
Only £149.99 inc VAT.
ORDER NOW
Avexir Tesla ROG Series 8GB (2x4GB) DDR4 PC4-21300C15 2666MHz Dual Channel Kit - Red Light @ £99.95 inc VAT
Avexir Red Tesla – ROG certified edition is carefully tuned for Asus Republic of Gamers (ROG) series motherboard from inside out. Red Tesla gaming memory modules are energized by plasma tube lighting effect. Impressive red lighting effect should be seen running in the machine to be believed. It is designed to delight gamers and enthusiasts by enhancing their computing experience and also deliver on our promise of “what we believe is how we behave”.
Red Tesla is built for your confidence which passed 16 hand-picked AIST (Avexir Ic Sorting Technology) processes and 14 memory module functional, burn in, and compatibility tests for newest DDR4 ROG motherboards. AVEXIR built top level specification of Red Tesla by using 10 layers performance optimized design printed circuit board and industrial grade resistors and capacitors.
XMP2.0 is the memory optimization technique developed by INTEL. You can simply install the modules to supported motherboards and get the performance enhanced via the BIOS menu just a click away by select XMP in the BIOS and you are ready to run.
Features:
- Exclusive patented technology of plasma tubes to mimic lightening effect
- Support XMP 2.0
Specification:
- Black PCB
- Red Plasma Strobe lightning effect (See product images)
- Lifetime Warranty
Only £99.95 inc VAT.
ORDER NOW
Avexir Tesla ROG Series 16GB (2x8GB) DDR4 PC4-21300C15 2666MHz Dual Channel Kit - Red Light @ £199.99 inc VAT
Features:
- Support XMP 2.0
Specification:
- Black PCB
- Lifetime Warranty
Only £199.99 inc VAT.
ORDER NOW
Avexir Tesla ROG Series 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit - Red Light @ £199.99 inc VAT
Features:
- Support XMP 2.0
Specification:
- Black PCB
- Quad Channel Kit: (4x4GB)
- Lifetime Warranty
ORDER NOW
View All Avexir Memory - Click Here!!
Features:
- Support XMP 2.0
Specification:
- Black PCB
- Lifetime Warranty
ORDER NOW
Features:
- Support XMP 2.0
Specification:
- Black PCB
- Lifetime Warranty
ORDER NOW
Features:
- Support XMP 2.0
Specification:
- Black PCB
- Lifetime Warranty
ORDER NOW
Features:
- Support XMP 2.0
Specification:
- Black PCB
- Lifetime Warranty
ORDER NOW
Features:
- Support XMP 2.0
Specification:
- Black PCB
- Lifetime Warranty
ORDER NOW
