Not sure why you want to change your cooler though.
Im starting to like the look of the Phanteks PH-TC14PE and it looks to perform on par with the NH-D15.. plus... it would match my case![]()
you got a picture? thats better temps than I get with my H80i!!!I've a £19.99 Themis cooler on my 4690k @4.6ghz and it maxes out about 67/68 when serious stress testing. Regular use is way less obviously. I did put on 2x 120mm EK Vardar's on just because I could.
thats a beast of a cooler Andy
do you think I could use the Phanteks PH-TC14PE and stay on 4.5Ghz on the 4690k?
James,
The Phanteks PH-TC14PE held the FX8350 at 4.5GHz in all except prime so I would think so.
cheers
Ive been on the fence for a while to be honest.. but after seeing the boys h60 leak over his gtx 970 its making me think...
I didint buy the H80i new!! I got it sealed but ive not got proof of purchase so if it was to go I wouldn't have any come back
We normally cover damaged hardware if one of our coolers leaks and caused the damage.But that will require a proof of purchase of the cooler for that process to unfold.
