Firefox Problem
29 Sep 2004
Wilt of the Shire
I'm using FF 42.0 and it wont open up any links when I click on them or when I right click to open in another tab. It was all working fine this morning.
I've tried using the edge browser and that works fine. I've also restarted a couple of times to see if that helps but nothing. I've not changed anything since this morning nor added/deleted any add ons.
Anyone else suffered from this?
Sussed it! I've got the new blocker enabled with this release of FF and google doesn't like to be blocked at all, they want more info from you. Anyway, I turned it off on google and now I can use it as before.
Strange, I use adblock with firefox and have not had this problem.
Adblock is fine, it's if you switch on the new blocker that comes with FF 42.0.
I tell a lie, it's nowt to do with FF. Just noticed that the icon on my toolbar belongs to the latest version of Kaspersky I installed. I thought it was the privacy tracker thing FF have just introduced, oh well turned it off for now :)
since update when i use fraps its overlayed in the top corner. all other additions havent done this what is changed ?
