- 22 Jul 2012
- London
You'd need a 980Ti or Titan X block.
I recommended the EVGA over reference cards because
A) EVGA are sweet as you like when it comes to removing coolers.
B) They have a transferable warranty, which covers anyone you may sell the card to.
C) The aircooler is way better than a ref card, should you ever need to use it
D) All that only costs an extra £30-40 for the privilege and will result in higher resale value vs a ref card
The other non-ref cards that are priced slightly lower don't offer any of these benefits - apart from having decent coolers.
ED:
If you do stick with the Poseidon, then you should probably grab a couple of 90° rotaries, as those side mounted fittings may become a bit too wide with added fittings and bent tube. It'll look better too.
ED:
