Win 10 download issue
2 Dec 2004
Under The Desk, Wales
Guys, i put Win 8 on my pc and activated fine. I went here and started to upgrade the PC.
Several times now it has it has restarted and an error has come up about memory dump!! Help!!
Can i put in the DVD of Win 10 and upgrade from that?
you can use the tool to download the DVD or make a USB stick.
are you on Windows 8 or 8.1?
Windows 8 cannot be upgraded to W10, it has to be windows 8.1 like W7 has to be SP1
Done all that but it may be that i have an iffy disc that may be corrupted
have you tried the USB option? that's what I used and had no issues when doing a clean install.
have you tried running the setup.exe from the HDD (download the ISO and extract the contents or burn to USB stick)
